RaceCapture-Track
Revision as of 06:24, 16 November 2016 by Brentp (talk | contribs) (→Analysis Mode)
Start it up
Plug it in
Download the app
Navigating dashboard screens
Setup Mode
<img src="WzHsdU1.gif" width="500"/>
Enabling Telemetry
Logs
Analysis Mode
Navigating data
Selecting Time vs Distance
Applying Decals
