RaceCapture-Track
Start it up
Plug it in
Download the app
- Google Play
- Amazon App Store
Setup Mode
- Note: Whenever you make a change on one of these pages, you will need to write your changes back to the RaceCapture device.
<img src="
" width="640"/>
Enabling Telemetry
Logs
Analysis Mode
Selecting time vs distance
Applying Decals
