RaceCapture-Track
Start it up
Plug it in
Download the app
- Google Play
- Amazon App Store
- Windows 10 and OSX: No drivers are needed for OSX or Windows 10.
- Windows XP, 7, 8: See the driver installation instructions below.
Setup Mode
- Note: Whenever you make a change on one of these pages, you will need to write your changes back to the RaceCapture device.
<img src="
" width="640"/>
Enabling Telemetry
Notes about Android devices
Logs
Analysis Mode
Selecting time vs distance
Applying Decals
More
Alternative ways to power
USB
You can power RaceCapture using the included USB cable, plugged into your car's USB charger, or you can power RaceCapture from a battery like the kind you would use to power a battery (1000 mAh or higher recommended)
Custom Cable
| +12v | Brown |
| Ground | Orange/White |
| CAN 1 High | Orange |
| CAN 1 Low | Green/White |
Recommended Tablets
Primary recommendation
- Nvidia Shield Tablet: $199.99 from Nvidia directly. Also available on Amazon and other retailers
Lower end recommendation
- Amazon Fire tablet: $49.95 edition
