RacecapturePro MK3 hardware install
Mounting Orientation
Alternative Mounting
- Example:
- Upside down
- Vertical / on edge
Main Connector
| Power | |
| Connection | Color |
| 12v | Red |
| Ground | Black |
| Voltage Reference | |
| Yellow | +5v reference |
| Analog Sensor Inputs | |
| White | Analog Input 1 |
| Gray | GPIO 1 |
| Auxiliary Serial Input | |
| CAN Bus | |
| Orange | CAN 1 Low |
Plug Connector Type
- Compatible Pins: Molex 46018-1541 or 46018-1541
Other connector sources
Cellular Telemetry
Antenna Placement Guide
Cellular antenna
Antenna separation
RJ45 CAN + Power connection
OBDII CAN cable
Custom Cable
| +12v | Brown |
| Ground | Orange/White |
| CAN 1 High | Orange |
| CAN 1 Low | Green/White |
| CAN 2 High | Blue |
| CAN 2 Low | Blue/White |
Analog Sensor inputs
| Voltage Range | 0-5v |
Connecting Sensors
| Voltage Range | 0-12v |
Signal input quality
Special note about RPM inputs
If your only source for RPM is the trigger wire driving the ignition coil primary winding, then you will need the CoilX module to buffer / filter the noisy, high-voltage component.
Connecting Sensors
See our RaceCapturePro_RPM RPM connection guide for more information connecting and calibrating these frequency / RPM channels.
GPIO
| Output mode type | Open Drain (connects ground when activated) |
| Input voltage protection | 0-40v - inductive protection up to 1A |
Input Mode
Important Note: when sensing large inductive loads, such as sensing brake light state or sensing motor state, connect a 10K 1/4 watt resistor in-line with the GPIO input to protect RaceCapture/Pro from a very large inductive spike.
Output Mode
Output Behaviour
GPIO Connections
Controlling GPIO Ports
Communications
CAN Channels 1 / 2
| CAN channels | 2 |
| CAN bus compatibility | CAN 2.0 compatible, 1M baud |
