BMW E36 Guide
BMW E36 (1990 - 1999)
- Timer Mode: RPM
- Timer Speed: Medium
- Pulse Per Revolution: 3
Engine Temperature
In research
Fuel Level
In research
(Needs verification)
- 0 ohms empty
- ?? ohms 1/4
- ?? ohms 1/2
- ?? ohms 3/4
- 260 ohms full
Oil Pressure
This calculates gear and speed based on the differential speed sensor. Assumes engine RPM is connected to the first RPM input.
setTickRate(10) --10Hz
--virtual channels
--global constants
first = 4.20
second = 2.49
third = 1.66
fourth = 1.24
fifth = 1.00
final = 3.46
tirediameter = 24.7
--global variables
rpm = 0
rpm_diff = 0
speed = 0
function updateSpeedDiff()
rpm_diff = getTimerRpm(1)
function updateGear()
rpm = getTimerRpm(0)
local gearErr = 0.15
local gear = 0
if speed > 2 then
ratio = rpm/(rpm_diff*final)
if ((first - ratio)^2) < (gearErr^2) then gear = 1 end
if ((third - ratio)^2) < (gearErr^2) then gear = 3 end
if ((fifth - ratio)^2) < (gearErr^2) then gear = 5 end
setChannel(gear_id, gear)
updateSpeedDiff()
updateGear()
