RaceCapturePro2 hardware guide
Revision as of 00:04, 9 August 2017 by Brentp (talk | contribs)
Quick Reference
Download a printable PDF
Power Connection
Via terminal block
Via RJ45 connection
You can also power via the RJ45 connector:
  • Important note The +12v connection on the RJ45 is connected internally to the +12v on the terminal block on RaceCapture/Pro MK2. It's recommended you only power via one source - RJ45 or terminal block - if you have both connected at the same time, you may cause back-feeding of power through RaceCapture/Pro, which may cause damage to the unit.
Analog Inputs 1-7
  • Input Impedance: 1 megaohm
Active Sensors/Signals
Resistive sensor
Analog Calibration
Tapping into existing Sensors
Connection
  • Important: when tapping into existing sensors that are wired into an existing gauge or ECU, do not connect an additional pull-up resistor. The existing gauge or system already provides whatever circuitry is needed to drive the sensor.
Calibration
First, you will need to determine the voltage curve: You will need to know if the sensor responds linearly or on a curve.
Linear
    • If the sensor response is linear, then you will need to know just two points: the voltage at the low end of the gauge, and the voltage at the high end of the gauge.
  • 0 PSI = 0.5 v
  • 150 PSI = 4.5 volts
You would adjust the analog mapping to set the scale so that: 0.5 volts = 0 PSI and 4.5 volts = 150 PSI
Curved response
Thermistor-based temperature sensors typically will have a curved response. This is more complex to map, but RaceCapture/Pro offers the ability map multiple points across this curve, and will linearly interpolate between points.
As the sensor's temperature, pressure (or whatever the sensor is reading) rises, the voltage sensed may increase or decrease. Use the manufacturer's specifications to map these values into the analog sensor configuration. If you do not have the manufacturer's specifications, you will need to take voltage readings across the range of the sensor.
  • The default calibration value is 1.0 - you can adjust it up or down to fine tune to match your electrical system.
  • When configured for input, the channel accepts a 0-5v input (protected up to 400V).
  • When configured for output, the channel provides an open-drain output that can drive 1A and is thermal / over-current protected with inductive load clamping.
Frequency/Pulse Input 1 - 3
TACH SIGNAL NOTES
CoilX Sensor Module
CAN bus port
  • See the quick reference guide for pinout
RaceCapture/Pro MK2 has built-in CAN termination on both ports.
Disabling CAN termination
Disabling CAN termination requires modification of the circuit board. The process is different based on the revision of the board:
  • Identifying board revision: The board revision is located to the left of the SD card slot, in the lower left corner of the main circuit board.
  • Revision J Boards:
Disabling termination involves removal of the 120 ohm surface mount resistors corresponding to each CAN channel. The resistor can be removed by using a soldering iron tip and applying heat to both side of the resistor until the solder melts and the resistor slides off of the pad.
    • CAN 1: Remove resistor R16, below the RJ45 port
    • CAN 2: Remove resistor R21, below the RJ45 port.
  • Revision K boards:
Disabling termination on Revision K boards involves breaking a PCB trace jumper for the corresponding CAN channel. The best way is to use the edge of a small jeweler's or precision screwdriver blade to scratch the trace away until you can clearly see the trace has been broken.
    • CAN 1: Break the trace on the jumper pad above and to the left of R16,
    • CAN 2: Break the trace on the jumper pad above and to the left of R21
Restoring CAN termination
To restore CAN termination, you can have the following options:
  • Add an external 120 ohm, 1/4W resistor as closely as possible to the RJ45 connector
  • Revision K board: apply solder to re-bridge the jumpers that were previously broken.
  • Revision J board: Re-solder a 0603 resistor to the R16 or R21 pads, depending on the CAN channel needing termination.
SD Card Slot
USB Port
LED Indicators
  • Power LED
  • GPS LED
  • Logging LED
  • Telemetry LED
Indicates telemetry activity.
    • A slow flash interval indicates connection initialization
    • A regular flash matching the highest logging rate (up to 10Hz) indicates connected and streaming
Pushbutton
  • Note this may be overridden by any on-board scripts that may automatically start or stop logging.
Communication Ports
  • Ext Telemetry / Bluetooth - Used for Bluetooth module
  • Auxiliary port - used for integrating external systems / devices
GPS port
  • Tighten this to 3-5 inch/lbs. This connection should be snug.
  • To prevent damage to the connector, do not over-tighten
Telemetry port
Physical Installation
  • Dimensions: 5.3" (width) x 4.2" (height) x 1.2" (tall) / 135x110x31 mm(est)
  • Mounting area: 5.5"(140mm) x 4"(102mm)
  • Mounting fasteners: Dual mounting points on 5" (127mm) centers - 0.125"-0.25" (3-6mm) fastener
Shock isolation mounting
