BMW E36 Guide
Revision as of 03:57, 11 November 2017 by Sbarton (talk | contribs) (→Fuel Level)
BMW E36 (1990 - 1999)
  • Timer Mode: RPM
  • Timer Speed: Medium
  • Pulse Per Revolution: 3
Engine Temperature
In research
Fuel Level
Mapping in RCP
  • 0.2v = 0 (empty)
  • 1.33v = 25 (1/4)
  • 2.2v = 50 (half)
  • 2.95v = 75 (3/4)
  • 3.53v = 100 (full)
You may want to average your fuel readings to compensate for slosh.
(Needs verification)
  • 0 ohms empty
  • ?? ohms 1/4
  • ?? ohms 1/2
  • ?? ohms 3/4
  • 260 ohms full
Oil Pressure
Assumes:
  • Engine RPM is connected to the first timer input.
  • Differential speed pulse is connected to the 2nd timer input
  • Pin 2 on connector X17 to the back of the gauge cluster
  • Pin 10 on connector X22 on the cruise control module behind the glove box
  • Pin 10 on radio connector
setTickRate(10) --10Hz
--virtual channels
--global constants
first = 4.20
second = 2.49
third = 1.66
fourth = 1.24
fifth = 1.00
final = 3.46
tirediameter = 24.7
--global variables
rpm = 0
rpm_diff = 0
speed = 0
function updateSpeedDiff()
   rpm_diff = getTimerRpm(1)
function updateGear()
   rpm = getTimerRpm(0)
   local gearErr = 0.15
   local gear = 0
   if speed > 2 then
      ratio = rpm/(rpm_diff*final)
      if ((first  - ratio)^2) < (gearErr^2) then gear = 1 end
      if ((third  - ratio)^2) < (gearErr^2) then gear = 3 end
      if ((fifth  - ratio)^2) < (gearErr^2) then gear = 5 end
     setChannel(gear_id, gear)
  updateSpeedDiff()
  updateGear()
External Reference
