RaceCapture troubleshooting
- Ensure the RaceCapture app is connected to RaceCapture
- In the RaceCapture app press the top menu button and select 'System Status'
RaceCapture Log
To access the RaceCapture Log
- Navigate to Setup and then select the Scripting screen (RaceCapture/Pro and RaceCapture/Apex) or the Logs screen (RaceCapture/Track)
- Check the box next to Poll Log at the bottom of the screen.
- The RaceCapture app will periodically query RaceCapture for log information. The log window will show messages from RaceCapture - scan these message for any errors. You can also copy the text in the log for future reference.
Application Log
- Navigate to the System Status page
- Select the Application section of the page
- Press the Copy button. This will copy the current application log to the system's clipboard.
- Paste the log into an email or document to review it's contents.
Saving your configuration
- Launch the RaceCapture app
- Connect your RaceCapture system to the app
- Navigate to Setup view.
- Press the Read button to read the current configuration
- Press the Save button to save the current configuration to the file you specify.
- Determine the location of the datastore file
Example:
... [Base ] Start application main loop [UserPrefs ] Saving preferences [Main ] Datastore Path:/home/susy/.config/racecapture/datastore.sq3 [Main ] initializing datastore... [RacecaptureApp] initializing rc comms with, conn type: Serial [RCPAPI ] msg_rx_worker starting [RCPAPI ] cmd_sequence_worker starting [RCPAPI ] auto_detect_worker starting ...
- Backing up and removing the current datastore.sq3
- Re-launching the RaceCapture app
