Podium Driver Data Analysis
Analyizing data in Podium
You can use Podium.live to find areas on the track and driving techniques to improve on in order to reduce your lap times and become a better driver.
Setup and Configure Podium
The first thing you want to do is find a few of your fastest laps and click on 3 of them. Ideally they will be laps close to each other as what we are analyzing is your consistency. Ideally, if you have a pro driver or coach who can set some reference data for you, click on your two fastest laps and their fastest lap. This will really show you where you can find time. Click on the fastest lap last, as the lap last you click on is used as the reference lap for the Time Gap Graph. Also make sure you graphs are by Distance and not Time. Now hide all the graphs we don't care about except Speed, Time Gap, AxcelX, AxcelY. You can keep RPM, Gear, Pitch and Yaw if you want. Customize the graphs so that the Min and Max values make sense for the data shown and give you the best resolution. Ie. If your car only rev's to 6000RPM, but max on the graph is 10000, maybe change the max to 6500.
Looking at the Time Gap graph shows you exactly how much time you are losing (or gaining) in a section. Look for the sections where the line rises or falls sharply. These are the areas you need to focus on and can learn from. The sections with the most amount of time lost (how far the dip is), are the sections you want to work on first (low hanging fruit). If your fastest lap was the last selected, it should be the reference lap. When the Time Gap line on another lap falls sharply, you are losing time in that section, when the line rises sharply, you are gaining some time back. You need to pay attention to both areas. Where the line rises means you probably could have gone faster there on your fastest lap. Now that we know which sections you need to work on and which of those sections you should work on first we need to analyze why you were slower in those sections. Go back to the speed trace graph and look at the section you are losing the most time on. Look where the difference starts happening. Is it in the braking zone, mid corner, or track out? If it is in the braking zone, are you braking too early, too little, too hard, is your pressure inconsistent throughout the braking zone. Are you not transitioning from throttle to full brakes fast enough, is your heel-toe messing up your braking pressure (check Accel as well) If mid corner speed; are you slowing down too much, did you not slow down enough and overcooked the turn a little, are you coming off the brakes at the right time, Is your turn in point the same, did you make it to the apex, how is your transition back to throttle (check Accel graph as well). If corner exit speed (and speed down following straight) is down; how was your mid corner speed, when did you get back onto throttle, when did you get to full throttle (check Accel graph), did you hit the apex and track out, what were your shift points (check RPM, Gear, and/or Accel graphs).
General Data Analysis tips
You only need to look at one lap at a time for this, use your best lap. Compare to your second best lap to see if they are similar to rule out an anomaly.
Braking
Look at the Accel graph that shows acceleration and braking. This will either be AccelX or AccelY depending on how you mounted and setup your RCP. You can tell which is your acceleration/braking graph because braking is always much larger curve than acceleration. Look for a graph with 0.2-0.3g's one side and over 1.0 g's on the other side.
Your max braking G's should be similar to your max turning G's (within about a 0.1g or so). If they are not close, it means you are not using your tires full potential for which ever graph is lower. Ie, if you are turning at 1.4g's, but your braking is only 1.0g, you can brake harder.
Throttle to Brakes transition
Heel-Toe
Look for a little blip in the braking trace. It will fall sharply, start to even out just the tiniest bit, then continue to fall sharply. This is where you are heel-toeing and let off a little brake pressure as you did so. You would need to work on your heel-toe without effecting the braking pressure.
Now draw a straight line through all of your major braking zones. Assuming the track conditions are the same (not going up or down a hill) at the brake zones, all these lines should be almost perfectly parallel to each other. This would mean you are using the brakes consistently at every braking zone. If any are less steep than others, you can get on the brakes harder in those less steep sections.
Lateral G's
