RaceCapturePro Lua Scripting
Example Scripts and How-Tos
Lua Script Basics
Writing your script
onTick() function
function onTick() println("hello from RaceCapture/Pro") end
Viewing the output log
Controlling the onTick() rate
count = 0 setTickRate(10) function onTick() count = count + 1 println("Tick: " ..count) end
Given:
function onTick() temperature = getAnalog(0) if temperature > 212 then setGpio(0, 1) else setGpio(0, 0) end end
Combining multiple functions
Example:
Debugging your script
Example:
function onTick() temperature = getAnalog(0) println("current temp: " ..temperature) if temperature > 212 then println("over temp!") setGpio(0, 1) else println("under temp") setGpio(0, 0) end end
Out of memory issues
If you are seeing out of memory issues, try the following:===Mark variables in your script as local===Lua makes variables global by default, which is typically opposite of other programming languages. Since global variables consume more memory, try making variables declared in your function local:
Lua Reference
More examples
API Reference
getGpio( channel )
- params
- channel: integer 0 - 2
- returns:
setGpio ( channel, state )
- params
- returns:
- none
getButton()
- params
- none
- returns
PWM / Analog Output functions
- params
- returns
- none
setPwmClockFreq( frequency )
- params
- returns
- none
- params
- returns
- none
Timer / RPM Sensor Functions
getTimerRpm(channel)
- params
- returns: RPM value
getTimerPeriodMs(channel)
- params
- returns: millisecond value
getTimerFreq(channel)
- params
- returns: Frequency in Hz
getTimerRaw(channel)
- params
Analog Sensor Functions
getAnalog(channel)
- params
getImu(channel)
- params
- returns
getImuRaw(channel)
- params
- returns
- The raw accelerometer value
GPS Sensor Functions
getGpsPos()
- params
- none
- returns
getGpsSpeed()
- params
- (none)
- returns
- The current speed in MPH
getGpsQuality()
- params
- (none)
- returns
getGpsSats()
- params
- (none)
- returns
getGpsTime()
- params
- (none)
- returns
- The current GPS time value
getGpsDist()
- params
- (none)
- returns
- The distance, in Miles
getGpsAltitude()
- Added: v2.9.0
- Parameters: None
- Returns: <altitude>
getLapCount()
- params
- (none)
- returns
getLapTime()
- params
- (none)
- returns
getPredTime()
as of 2.12.0 firmware
- params
- (none)
- returns
getGpsSec()
- params
- (none)
- returns
getAtStartFinish()
- params
- (none)
- returns
getTimeDiff(time1, time2)
- params
- time1
- time2
- returns
getTimeSince(time)
- params
- time
- returns
CAN Bus functions
initCAN(channel, baud )
- params
- returns
- params
- returns
Example:
rxCAN(channel, [timeout] )
- params
- returns
Example:
- params
- returns
readOBD2( PID )
- params
- returns
Logger Control Functions
onTick()
- params:
- (none)
- returns:
- (none)
Example:
setTickRate(rate)
- params
- returns
- (none)
SD Logging control
isLogging()
- params
- (none)
- returns
startLogging()
- params
- (none)
- returns
- (none)
stopLogging()
- params
- (none)
- returns
- (none)
setLed( led, state )
- params
- led (1-3)
- returns
- (none)
setBgStream( on/off )
- params
- returns
- (none)
getBgStream()
- params
- (none)
- returns
Serial Port Communications
Port mappings
0 = USB port
1 = GPS port
2 = Internal telemetry port (MK2/3/Apex only)
3 = Bluetooth port
4 = Auxiliary / WiFi port
5 = WiFi port
6 = External Auxiliary port (RaceCapture/Pro MK3 and RaceCapture/Apex only)
- params
- returns
readCSer( port, [timeout])
- params
- returns
readSer( port, [timeout])
- params
- port: Serial port 0 - 4
writeCSer( port, data )
- params:
- returns:
(no return values)
writeSer( port, data )
- params
- returns:
(no return values)
flashLoggerCfg()
- params
- (none)
- returns
- (none)
setPwmClockFreq( freq )
- params
- returns
- (none)
getPwmClockFreq()
- params
- (none)
- returns
calibrateImuZero()
- params
- (none)
- returns
- (none)
Virtual Channels
- params
- returns
- Parameters
- Returns
- (number) The current value of the channel if available, or nil if the value is not available. You should always check if the value is present before using it for other purposes.
- Examples:
--get the channel by name rpm = getChannel("RPM") if rpm ~= nil then println("rpm channel: " ..rpm) end
- params
Example:
id = addChannel("EGT", 1) function onTick() temp = getAnalog(0) --read analog channel 0 temp = temp * 1000 setChannel(id, temp) --sets the virtual channel value end
Time Info
getUptime()
- Returns
getDateTime()
- Year
- Month
- Day
- Hour
- Minute
- Second
- Millisecond
