RaceCapturePro Lua Scripting
Example Scripts and How-Tos
Lua Script Basics
Writing your script
onTick() function
Viewing the output log
Controlling the onTick() rate
count = 0
count = count + 1
println("Tick: " ..count)
Given:
temperature = getAnalog(0)
if temperature > 212 then
setGpio(0, 1)
else
setGpio(0, 0)
Combining multiple functions
Example:
Debugging your script
Example:
println("over temp!")
setGpio(0, 1)
else
println("under temp")
setGpio(0, 0)
Out of memory issues
Simplify your script
Try a Lua minimizer
Lua Reference
More examples
API Reference
getGpio( channel )
- params
- channel: integer 0 - 2
- returns:
setGpio ( channel, state )
- params
- returns:
- none
getButton()
- params
- none
- returns
PWM / Analog Output functions
- params
- returns
- none
setPwmClockFreq( frequency )
- params
- returns
- none
- params
- returns
- none
Timer / RPM Sensor Functions
getTimerRpm(channel)
- params
- returns: RPM value
getTimerPeriodMs(channel)
- params
- returns: millisecond value
getTimerFreq(channel)
- params
- returns: Frequency in Hz
getTimerRaw(channel)
- params
Analog Sensor Functions
getAnalog(channel)
- params
getImu(channel)
- params
- returns
getImuRaw(channel)
- params
- returns
- The raw accelerometer value
GPS Sensor Functions
getGpsPos()
- params
- none
- returns
getGpsSpeed()
- params
- (none)
- returns
- The current speed in MPH
getGpsQuality()
- params
- (none)
- returns
getGpsSats()
- params
- (none)
- returns
getGpsTime()
- params
- (none)
- returns
- The current GPS time value
getGpsDist()
- params
- (none)
- returns
- The distance, in Miles
getGpsAltitude()
- Added: v2.9.0
- Parameters: None
- Returns: <altitude>
getLapCount()
- params
- (none)
- returns
getLapTime()
- params
- (none)
- returns
getPredTime()
as of 2.12.0 firmware
- params
- (none)
- returns
getGpsSec()
- params
- (none)
- returns
getAtStartFinish()
- params
- (none)
- returns
getTimeDiff(time1, time2)
- params
- time1
- time2
- returns
getTimeSince(time)
- params
- time
- returns
CAN Bus functions
initCAN(channel, baud )
- params
- returns
- params
- returns
Example:
channel = 0
id = 1234
ext = 0
data = {11,22,33}
rxCAN(channel, [timeout] )
- params
- returns
Example:
- params
- returns
readOBD2( PID )
- params
- returns
Logger Control Functions
onTick()
- params:
- (none)
- returns:
- (none)
Example:
setTickRate(rate)
- params
- returns
- (none)
SD Logging control
isLogging()
- params
- (none)
- returns
startLogging()
- params
- (none)
- returns
- (none)
stopLogging()
- params
- (none)
- returns
- (none)
setLed( led, state )
- params
- led (1-3)
- returns
- (none)
setBgStream( on/off )
- params
- returns
- (none)
getBgStream()
- params
- (none)
- returns
Serial Port Communications
Port mappings
- 0 = USB port
- 1 = GPS port
- 3 = Bluetooth port
- 4 = Auxiliary / WiFi port
- params
- returns
readCSer( port, [timeout])
- params
- returns
readSer( port, [timeout])
- params
- port: Serial port 0 - 4
writeCSer( port, data )
- params:
- returns:
(no return values)
writeSer( port, data )
- params
- returns:
(no return values)
flashLoggerCfg()
- params
- (none)
- returns
- (none)
setPwmClockFreq( freq )
- params
- returns
- (none)
getPwmClockFreq()
- params
- (none)
- returns
calibrateImuZero()
- params
- (none)
- returns
- (none)
Virtual Channels
- params
- returns
- Parameters
- Returns
- (number) The current value of the channel if available, or nil if the value is not available. You should always check if the value is present before using it for other purposes.
- Examples:
--get the channel by name
rpm = getChannel("RPM")
if rpm ~= nil then
- params
Example:
id = addChannel("EGT", 1)
temp = temp * 1000
Time Info
getUptime()
- Returns
getDateTime()
- Year
- Month
- Day
- Hour
- Minute
- Second
- Millisecond
ShiftX2/3 control
The following functions provide access to the ShiftX2 or ShiftX3 RGB sequential shift light.
sxSetConfig()
sxSetConfig()
- params
- Enable / Disable button events: 0 (Enable button event broadcast to app); 1 (Disable button event broadcast to app)
- returns
sxCfgLinearGraph()
- params
- returns
sxSetLinearThresh()
- params
- Red: Red LED value (0-255)
- Flash: 0-10Hz (0 = sold on)
- returns
sxUpdateLinearGraph()
- params
- returns
- (none)
sxSetAlert()
Direct set an alert indicator.
- params
- returns
sxSetAlertThresh()
- params
- Alert ID: ID of alert threshold (0-4)
- returns
sxUpdateAlert()
- params
- returns
sxSetDisplay()
- params
- Digit index (must be 0)
- returns
sxSetLed()
- params
- returns
sxRxButton()
- params
- (none)
- returns
- button_id (ID of button. left button = 0, right button = 1)
