Jump to integrated cellular telemetry guide
Jump to telemetry via RaceCapture app guide
<img src="
" width="640"/>
Prerequisites
Get a device Id
Integrated cellular telemetry
Supported devices
- PodiumConnect
- RaceCapture/Apex
- RaceCapture/Pro MK3, MK2
Get a SIM card
Which SIM card to get?
USA
Freedom Pop
We currently recommend the $0/month plan from FreedomPop. Based on the AT&T network, it offers the best performance in rural areas across the USA.
- Note: When signing up, FreedomPop will place you in a default monthly plan. If you want their basic $0/month plan, you will need to downgrade using your account - click through the warning messages until you're at the Basic/Free plan. When you are done, your billing page should show $0/month.
AT&T
AT&T is our second recommendation as they have announced affordable plans targeting tablets and other data-only devices.
When you arrive at the store:
- Critically important: Ask for a pre-paid SIM card for a tablet data plan. It must be a tablet data plan; problems have been reported with phone SIMs.
- Request a full-sized SIM (RaceCapture/Pro) or a micro SIM (RaceCapture/Apex)
- IMEI: usually they will use a default IMEI. If they require one, you can from the system status page
- Important note about AT&T and legacy 2.5G modules in RaceCapture/Pro MK2
- Use a carrier that still supports 2G Data, such as T-Mobile
- Upgrade your RaceCapture/Pro MK2 with the 3.5G module
T-Mobile
- Ask for a pre-paid $3/day plan
- IMEI: usually they will use a default IMEI. If they require one, you can get the IMEI from the system status page
Global
RaceCapture/Pro MK3, RaceCapture/Apex and PodiumConnect use a world-wide compatible GSM cellular module. Check with your carrier for support. You will also likely need to set a custom APN setting in the telemetry configuration; the carrier will have these APN settings available.
You will need:
- APN Host
- APN User name (might be blank)
- APN Password (might be blank)
Enter these values into the cellular provider section under Setup / Wireless:
How much data will I need?
- Number of channels enabled
- Sample Rate of channels
Installing the SIM card
RaceCapture/Apex
- Remove the cover from the rear of the enclosure, and insert the SIM card into the bottom slot of the silver card holder (below the top SD card position).
RaceCapture/Pro MK3
- Use a pen, stylus or similar press the eject button next to the SIM card slot on the front panel - the card slot will pop out slightly. Manually withdraw it.
- Insert the SIM card into the holder, noting the angled notch. Re-insert with the SIM card facing up and press until the front edge is flush with the face, until you feel the tray seat.
- Important: The card carrier should slide in smoothly, and require just a bit of force to lock in to place. Take care to not force the card in at an angle.
RaceCapture/Pro MK2
- Use a pen, stylus or similar press the eject button next to the SIM card slot - the card slot will pop out slightly. Manually withdraw it.
- Insert the SIM card into the holder, noting the angled notch. Re-insert with the SIM card facing down and press until the front edge is flush or just below the surface of the enclosure face, and you feel the tray seat.
SIM adapters
Attach cellular antenna
- Important: Do not over-tighten antenna connection
Antenna placement
Telemetry Configuration
- Launch the RaceCapture app and connect to your RaceCapture hardware.
- Once it connects, navigate to Setup
Enable Telemetry
- Under Setup, select Telemetry section.
- In the Device ID field, enter the Device Id provided by your podium.live account.
Enable Cellular
- if your carrier is not listed, select other and specify the APN settings provided by your wireless company.
- List of APNs worldwide
Write Configuration
- Write your configuration back to the RaceCapture unit
- It's recommended you also save your configuration to a file for safe keeping.
Testing and Verification
Powering up
3.5G module
- Applies to: RaceCapture/Apex, RaceCapture/Pro MK3, MK2 (with 3.5G option)
2.5G module
- Applies to: RaceCapture/Pro MK2 (with 2.5G option), MK1
Watching for telemetry
- Note: You can also edit and rename this event.
LED indicators
RaceCapture/Apex
- Observe the blue telemetry status indicator on the top of the unit.
RaceCapture/Pro MK3
- Observe the blue telemetry status indicator on the front panel of the unit.
RaceCapture/Pro MK2
- When connected and transmitting, the top-right green telemetry LED will flash rapidly and steadily.
- Missing / Incorrect Device Id: Ensure RaceCapture/Pro is configured with a Device ID provided by your Podium account.
- Cellular disabled: Ensure the the Cellular option is set to on in the Wireless settings under Setup.
- Expired SIM card: Make sure your SIM card has enough credit to enable data.
- Poor signal quality: Ensure adequate coverage in the area.
- Loose / incorrect antenna connection: Ensure the antenna is correctly torqued to 4-6 inch/lbs (just beyond finger-tight) and connected to the correct antenna port.
- No 12v power (2.5G cellular only) The 2.5G internal telemetry module requires external 12v (via green terminal block or OBD-II cable)
- Note: 3.5G cellular telemetry can be powered by USB.
Debugging Cellular activity
You can use this log output for additional messages around cellular initialization and connectivity.
RaceCapture App Telemetry
Using the RaceCapture app, you can broadcast telemetry while using the dashboard features in the app, including pit-to-car alerts.
Pre-requisites
Ensure you have a high quality 12v charger connected to the Android or iOS device so the device maintains charge throughout your race event.
Telemetry via direct USB connection + hotspot
You can broadcat telemetry via the RaceCapture app while using a direct USB connection to the RaceCapture system:
- USB OTG via Android
- Direct USB Host using an Android stereo receiver
- Direct USB Host using a Raspberry Pi
- System Compatibility:
- RaceCapture/Apex
- RaceCapture/Pro MK3 / MK2
- RaceCapture/Track MK2 / MK1
- PodiumConnect
Telemetry Via Bluetooth connection + hotspot
You can broadcast telemetry via the RaceCapture app while using the Bluetooth connection on compatible Android devices.
- Note You can also use an Android Phone in place of the hotspot.
- RaceCapture/Apex
- RaceCapture/Pro MK2 (with Bluetooth module)
- RaceCapture/Pro MK1 (with Bluetooth module)
You can broadcast telemetry via the RaceCapture app by connecting both RaceCapture and your Android or iOS device to a common WiFi hotspot. Data flows from RaceCapture to the RaceCapture app, which is then broadcast to Podium.
Configure RaceCapture to connect to the hotspot by specifying the SSID and password under the WiFi client settings, located in the RaceCapture app under Setup/Wireless. Then, configure your Android or iOS device to connect to the same hotspot.
- Note: You must use the RaceCapture app to broadcast telemetry, RaceCapture does not directly broadcast telemetry directly via WiFi.
- PodiumConnect
- RaceCapture/Apex
- RaceCapture/Track MK1
- RaceCapture/Pro MK2 (with WiFi module)
- Launch the RaceCapture app and connect to your RaceCapture hardware via Bluetooth or WiFi
Enable Telemetry
Disable Cellular
- Select the Wireless section
- Ensure Cellular telemetry is disabled, if the option is available.
Write Configuration
Verify Telemetry
- Dim Green Not active
- Red Connection Error
- Missing / Incorrect Device Id: Ensure the Device ID provided by your Podium account is correctly set.
- App Telemetry disabled: Ensure the "Send Telemetry" option is enabled under the RaceCapture App preferences.
- Cellular enabled: If the Cellular option is available under the Wireless settings under Setup, ensure it is set to off - otherwise the system will assume you want to broadcast via the internal cellular module.
- No data available on plan: Verify internet connectivity on the phone or tablet using a simple browser connectivity test.
