MJLJ V4 Operation Guide
Revision as of 09:09, 2 June 2008 by Brentp (talk | contribs) (Controller Options: V4 updates)
First time use
Setting the Serial Port
Configuring MAP or TPS
Connecting to the MJLJ
Common connection problems
Timeout reading runtime data
Could not open port
Either:
At a glance: Main Screen
Runtime Gauges
Ignition Advance
Load
Ignition Map
Editing Ignition Map
Adjusting ignition advance
  • Changing single value
  • Changing multiple cells
Adjusting Load / RPM Bins
  • Ctrl-B in the main window
Controller Options
User Configurable Outputs
Output Type
Output Mode
Activation Point
Hysteresis on outputs
  • Auxiliary configured outputs: Hysteresis is set at 1 Unit.
Shift Light
Rev Limit
Commit to Flash
Additional Options
Load Axis Calibration
Guided TPS calibration
Advanced Uses
Load / Save calibration
Edit Values
Enabling Switchable Ignition Configurations
Enable hardware switch
Important Usage Notes
Charting / Runtime view
Tuning Perspective
Editing the Ignition Map
Hot Keys
Data logging
Quick Data Logging
Mark Datalog
Stop Logging
Logfile Format
  • RPM: Engine RPM
Advanced Topics
