Harness specifications
Revision as of 19:00, 14 September 2020 by Brentp (talk | contribs) (→CAN Y-adapter)
Standardized Connections
The following represents the Autosport Labs standard power, CAN, and analog signaling standard for 2020 and on.
Connector Standard
Power + CAN
Single CAN interconnect
Dual CAN interconnect
Single analog/digital channel
Quad analog/digital channels
Available CAN bus cabling
CAN extension cables
Orderable SKU Description
ASL_M8_CAN_PATCH_1M 1 meter CAN extension cable
ASL_M8_CAN_PATCH_2M 2 meter CAN extension cable
ASL_M8_CAN_PATCH_3M 3 meter CAN extension cable
ASL_M8_CAN_PATCH_4M 4 meter CAN extension cable
CAN Y-adapter
The CAN Y-adapter/splitter splits a single CAN bus so a device can be inserted within a loop.
M8 CAN + power pigtail
Used as a primary power + single CAN bus connection for a single wire setup.
Dual CAN interconnect (RJ45)
