Harness specifications
Standardized Connections
- Connector: M8 4P, A coding
Male connector pictured
Pin | Connection | Notes |
1 | CAN low | White |
3 | CAN high | Green |
4 | Ground | Black |
Dual CAN + power interconnect
- Connector: M8 6P, A coding
1 | CAN1 low | |
2 | CAN2 low | |
3 | CAN2 high | |
4 | Ground | |
5 | CAN1 high | |
Single analog/digital channel
- Connector: M8 3P, A coding
1 | Ground | Brown |
4 | Signal | Black |
Quad analog/digital channels
1 | Analog/Digital 1 | |
2 | Analog/Digital 2 | |
3 | Analog/Digital 4 | |
5 | Ground | |
7 | Analog/Digital 3 | |
8 | Ground |
Octo analog/digital channels
- Connector: M8 12P, A coding
10 | Ground | ||
11 | Ground | ||
12 | Ground |
Available cabling
CAN extension cables
Orderable SKU | Description |
ASL_M8_CAN_EXT_0.5M | 0.5 meter CAN extension cable |
ASL_M8_CAN_EXT_1M | 1 meter CAN extension cable |
ASL_M8_CAN_EXT_2M | 2 meter CAN extension cable |
ASL_M8_CAN_EXT_3M | 3 meter CAN extension cable |
ASL_M8_CAN_EXT_4M | 4 meter CAN extension cable |
CAN splitter
ASL_CAN_SPLITTER | Single channel CAN splitter |
M8 Power + CAN pigtail
ASL_POWER_CAN_PIGTAIL_2M | Power + CAN pigtail, 2 meter |
Pinout
- Red / Pin 2: +12v
- Black / Pin 4: Ground
- White / Pin 1: CAN Low
- Green / Pin 3: CAN High
M8 Power + CAN device pigtail
- Note For a plug and play installation, use the CAN extension cables to integrate with the CAN.
ASL_DEVICE_CAN_PIGTAIL_1M | Power + CAN pigtail for individual devices, 1 meter |
Pinout
- Red / Pin 2: +12v
Dual CAN interconnect (RJ45)
ASL_DUAL_CAN_RJ45_M8_1M | Dual CAN RJ45 to M8 6P male, 1 meter |
ASL_DUAL_CAN_M8_1M | Dual CAN M8 6P male to M8 6P male, 1 meter |
Inline CAN terminator
ASL_CAN_TERMINATOR | Inline CAN terminator, M8 4P |
Analog/Digital cabling
Sensor Pigtail
ASL_M8_SENSOR_PIGTAIL_2M | M8 3P to bare wire sensor pigtail, 2M, 24 AWG |
Sensor Extension Cable
ASL_M8_SENSOR_EXTENSION_1M | M8 3P sensor extension cable, 1 meter |
ASL_M8_SENSOR_EXTENSION_2M | M8 3P sensor extension cable, 2 meter |
ASL_M8_SENSOR_EXTENSION_3M | M8 3P sensor extension cable, 3 meter |
ASL_M8_SENSOR_EXTENSION_4M | M8 3P sensor extension cable, 4 meter |
ASL_4X_SENSOR_SPLITTER | 4X analog / digital sensor splitter |
- Note For plug and play installations, use a combination of the quad analog/digital sensor splitter, extension cables and plug and play sensors.
ASL_M8_QUAD_SENSOR_PIGTAIL_1M | M8 8P male to bare wire quad sensor pigtail, 1M, 24AWG |
Pinout
- White / Pin 1 : Analog/Digital 1
- Yellow / Pin 2 : Analog/Digital 2
- Gray / Pin 3 : Analog/Digital 4
- Red / Pin 4 : 5v reference
- Brown / Pin 5 : Ground
- Pink / Pin 6 : 5v reference
- Blue / Pin 7 : Analog/Digital 3
- Green / Pin 8 : Ground
ASL_DELPHI3_M8 | Delphi GT150 3 pin to M8, 2 meters |
ASL_LINEAR_TEMP_M8 | Autosport Labs linear temperature to M8, 2 meters |
