Harness specifications
Revision as of 16:20, 14 September 2022 by Brentp (talk | contribs) (→‎CAN extension)
Plug and Play harness system
CAN bus Harness
Click to view details
About this image
Analog harness
About this image
Dual CAN splitter
CAN extension
Inline CAN terminator
Power+CAN pigtail
CAN+power for device
M8-4P female to pigtail for connecting one of our CAN bus enabled devices such as TireX, AnalogX2, or ShiftX3 to a custom wired, non Plug and Play network. Product Info
8 channel extension
8 to 4 channel splitter
8 channel pigtail
4 channel extension
4 channel pigtail
4 channel splitter
Single channel extension
Single channel pigtail
Pressure sensor
Linear temperature sensor
  • Connector: M8 4P, A coding
Male connector pictured
Pin Connection Notes
1 CAN low White
3 CAN high Green
4 Ground Black
Dual CAN + power interconnect
  • Connector: M8 6P, A coding
1 CAN1 low
2 CAN2 low
3 CAN2 high
4 Ground
5 CAN1 high
6 Power 9-24v / 1A (~12W)
Single analog/digital channel
  • Connector: M8 3P, A coding
1 Ground Brown
3 Power Blue (5v @ 1A max)
4 Signal Black
Quad analog/digital channels
1 Analog/Digital 1
2 Analog/Digital 2
3 Analog/Digital 4
5 Ground
7 Analog/Digital 3
8 Ground
Octo analog/digital channels
  • Connector: M8 12P, A coding
6 Vref 5v @ 0.5A 5v @ 0.5A
10 Ground
11 Ground
12 Ground
Available cabling
CAN extension cables
Orderable SKU Description
CAN splitter
M8 Power + CAN pigtail
Pinout
  • Red / Pin 2: +12v
  • Black / Pin 4: Ground
  • White / Pin 1: CAN Low
  • Green / Pin 3: CAN High
M8 Power + CAN device pigtail
Pinout
  • Red / Pin 2: +12v
Dual CAN interconnect (RJ45)
Analog/Digital cabling
Sensor Pigtail
Sensor Extension Cable
Pinout
  • Red / Pin 4 : 5v reference
  • Brown / Pin 5 : Ground
  • Pink / Pin 6 : 5v reference
  • Green / Pin 8 : Ground
