Harness specifications
Plug and Play harness system
CAN bus Harness
Analog harness
The plug and play Analog/Digital harness system lets you easily connect individual sensors to your RaceCapture system, without the need to splice, crimp, or heat shrink connections. Multiple-length extension cables for each stage of the harness lets you build a harness that perfectly matches your installation needs.
CAN bus harness components
Dual CAN splitter
Dual CAN interconnect
M8-6P male to M8-6P male link cable for connecting two CAN bus networks to our Powered Dual CAN Hub Product Info
Powered dual CAN hub
Powered CAN hub featuring 8 ports (4 ports for CAN1 and 4 ports for CAN2). Use with the Dual CAN interconnect cable to link to your RaceCapture or PodiumConnect system. Product Info]
CAN Extension
CAN splitter
Inline CAN terminator
Power CAN pigtail
| Pin | Color | Connection |
| 1 | White | CAN low |
| 2 | Red | 9-24v / 1A (~12W) |
| 3 | Green | CAN high |
| 4 | Black | Ground |
CAN+power for device
8 channel extension
8 to 4 channel splitter
8 channel pigtail
- 24 AWG
| Pin | Color | Connection | Analog Mapping | Digital Mapping |
| 1 | Blue | Analog/Digital B1 | Analog 5 | GPIO 1 |
| 2 | Yellow | Analog/Digital B2 | Analog 6 | GPIO 2 |
| 3 | Green | Analog/Digital B4 | Analog 8 | GPIO 4 |
| 4 | Pink | Analog/Digital A1 | Analog 1 | Timer/RPM 1 |
| 5 | White | Analog/Digital A2 | Analog 2 | Timer/RPM 2 |
| 6 | Red | Vref | 5v @ 0.5A | 5v @ 0.5A |
| 7 | Violet | Analog/Digital A3 | Analog 3 | Timer/RPM 3 |
| 8 | Orange | Analog/Digital A4 | Analog 4 | Timer/RPM 4 |
| 9 | Light Green | Analog/Digital B3 | Analog 7 | GPIO 3 |
| 10 | Grey | Ground | ||
| 11 | Brown | Ground | ||
| 12 | Black | Ground |
4 channel extension
4 channel pigtail
- 24 AWG
| 1 | White | Analog/Digital 1 |
| 2 | Yellow | Analog/Digital 2 |
| 3 | Grey | Analog/Digital 4 |
| 4 | Red | 5v reference |
| 5 | Brown | Ground |
| 6 | Pink | 5v reference |
| 7 | Blue | Analog/Digital 3 |
| 8 | Green | Ground |
4 channel splitter
Single channel extension
Single channel pigtail
- 24 AWG
| 3 | Blue | 5v |
| 4 | Black | Signal Input |
Pressure sensor
Linear temperature sensor
- Connector: M8 4P, A coding
Male connector pictured
| Pin | Connection | Notes |
| 1 | CAN low | White |
| 3 | CAN high | Green |
| 4 | Ground | Black |
Dual CAN + power interconnect
- Connector: M8 6P, A coding
| 1 | CAN1 low | |
| 2 | CAN2 low | |
| 3 | CAN2 high | |
| 4 | Ground | |
| 5 | CAN1 high | |
Single analog/digital channel
- Connector: M8 3P, A coding
| 1 | Ground | Brown |
| 3 | Power | Blue (5v @ 1A max) |
| 4 | Signal | Black |
Quad analog/digital channels
| 1 | Analog/Digital 1 | |
| 2 | Analog/Digital 2 | |
| 3 | Analog/Digital 4 | |
| 5 | Ground | |
| 7 | Analog/Digital 3 | |
| 8 | Ground |
Octo analog/digital channels
- Connector: M8 12P, A coding
| 9 | Analog/Digital B3 | Analog 7 | GPIO 3 |
| 10 | Ground | ||
| 11 | Ground | ||
| 12 | Ground |
