Harness specifications
Plug and Play harness system
CAN bus Harness
Analog harness
CAN bus harness components
Dual CAN splitter
M8-6P male to dual M8-4P female splits CAN1/CAN2 into individual CAN1 and CAN2 connections.
Dual CAN interconnect
Powered dual CAN hub
Powered CAN hub featuring 8 ports (4 ports for CAN1 and 4 ports for CAN2). Use with the Dual CAN interconnect cable to link to your RaceCapture or PodiumConnect system. Product Info
CAN extension
CAN splitter
Inline CAN terminator
Power CAN pigtail
Pin Color Connection
1 White CAN low
2 Red 9-24v / 1A (~12W)
3 Green CAN high
4 Black Ground
CAN+power for device
1 White CAN low
3 Green CAN high
4 Black Ground
8 channel extension
8 to 4 channel splitter
8 channel pigtail
  • 24 AWG
10 Grey Ground
11 Brown Ground
12 Black Ground
4 channel extension
4 channel pigtail
  • 24 AWG
1 White Analog/Digital 1
2 Yellow Analog/Digital 2
3 Grey Analog/Digital 4
4 Red 5v reference
5 Brown Ground
6 Pink 5v reference
7 Blue Analog/Digital 3
8 Green Ground
4 channel splitter
Single channel extension
Single channel pigtail
  • 24 AWG
1 Brown Ground
3 Blue 5v
4 Black Signal Input
Pressure sensor
M8 Pin GT150 Pin Connection
1 A Ground
3 B 5v Power
4 C Signal
Linear temperature sensor
  • Connector: M8 4P, A coding
Male connector pictured
Pin Connection Notes
1 CAN low White
3 CAN high Green
4 Ground Black
Dual CAN + power interconnect
  • Connector: M8 6P, A coding
1 CAN1 low
2 CAN2 low
3 CAN2 high
4 Ground
5 CAN1 high
6 Power 9-24v / 1A (~12W)
Single analog/digital channel
  • Connector: M8 3P, A coding
1 Ground Brown
3 Power Blue (5v @ 1A max)
4 Signal Black
Quad analog/digital channels
1 Analog/Digital 1
2 Analog/Digital 2
3 Analog/Digital 4
5 Ground
7 Analog/Digital 3
8 Ground
Octo analog/digital channels
  • Connector: M8 12P, A coding
6 Vref 5v @ 0.5A 5v @ 0.5A
10 Ground
11 Ground
12 Ground
