TireX
High Performance
Rugged and Compact
Flexible Setup
Quick Setup Guide
- RaceCapture system
- Powered CAN hub kit
Hardware Setup
TireX 4-corner plug and play harness
We recommend using the TireX 4-corner plug and play harness for the easiest installation.
By System
For newer plug and play RaceCapture and PodiumConnect systems
Using the Dual CAN hub
Get the 8 port hub and dual CAN link cable
https://www.autosportlabs.com/product/powered-8-port-dual-can-bus-hub-kit/
https://www.autosportlabs.com/product/racecapture-m8-to-dual-can-bus-link-cable/
Minimal installation using the Dual CAN splitter
For a minimal installation, use the Dual CAN splitter
https://www.autosportlabs.com/product/can1-can2-dual-can-splitter/
For older generation RaceCapture systems with RJ45 connector
Plug and Play option
Get the 8 port hub and dual CAN link cable -> RJ45
https://www.autosportlabs.com/product/racecapture-rj45-to-dual-can-bus-link-cable/
The cable plugs into the RJ45 port of your RaceCapture/Pro, and then plugs into the hub. Then, the TireX harness plugs into the hub.
Minimal installation (requires some custom wiring)
Get the Device CAN pigtail
https://www.autosportlabs.com/product/can-power-pigtail-for-device/
For other data systems
Get the Device CAN pigtail.
Provide power to the CAN hub
Software Setup
Enable the TireX CAN mapping
- Go to Setup/CAN mapping
Using the overview gauge
Using the raw channels view
Feature | Description |
Sensor type | Thermal array |
Accuracy | 1C |
Processing Engine | 32 bit |
Electrical | |
Interface | CAN 2.0 |
Power | 200mW |
CAN bus | |
Physical / Environmental | |
Construction | CNC aluminum |
Weight | 10 grams |
IP rating | IP65 |
Dimensions / Mounting
Mounting Orientation
Mounting Distance
- 205 width = 71mm
- 225 width = 79mm
- 235 width = 82mm
- 245 width = 85mm
- 255 width = 89mm
- 275 width = 96mm
- 315 width = 110mm
Electrical / CAN connection
Pin 1 | CAN Low | Brown |
Pin 3 | CAN High | Blue |
Pin 4 | Ground | Black |
CAN termination
Customizing Termination
Zone Configuration
Zones | Coverage |
CAN bus protocol
CAN protocol files
Formula
- Example:
- Formula: A / 100
- Real-world value: 0.95
Data encoding
Endian
Single and mulit-byte values
Value | Symbol Reference |
8 Bit values | A |
Default Main Base ID
Adjusting Main Base ID
Sensor Position Offset
0 | Left-Front | 0x0 (0) |
2 | Left-Rear | 0x200 (512) |
Left-Front | 0xA100 |
Right-Front | 0xA200 |
Left-Rear | 0xA300 |
Right-Rear | 0xA400 |
CAN ID: Sensor Base ID + 0
3 | Reserved | |||
4 | Reserved | |||
CAN ID: Sensor Base ID + 2
1 | Reserved | |||
2 | Reserved | |||
3 | Reserved | |||
4 | Reserved | |||
Configuration Preferences
CAN ID: Sensor Base ID + 3
4 | Reserved | |||
5 | Reserved | |||
6 | Reserved | |||
7 | Reserved |
Calibration Preferences
CAN ID: Sensor Base ID + 4
3 | Reserved | |||
4 | Reserved | |||
5 | Reserved | |||
6 | Reserved | |||
7 | Reserved |
1 Zone
2 Zones
4 Zones
8 Zones
16 Zones
Full Frame Mode
