ESP32-CAN-X2
ESP32-CAN-X2 is an innovative, and sophisticated development board that is specifically designed for CAN communication. This development board has all the features of a modern ESP32 development board, integrated Wi-Fi and Bluetooth, along with the extended CAN controller. AutosportsLabs has specifically designed it for advanced CAN communication along with fast processing and computation options. This is a complete how-to-use guide and this user guide will describe each and every step to use the board and harness the maximum potential of the board.
The prominent features of ESP32-CAN-X2 development board are as follows :
- The development board is based on ESP32-SE-WROOM-1-N8R8 microcontroller powerful dual-core Xtensa LX6 CPU running at up to 240 MHz.
- The development board has 384 KB ROM, 512 KB SRAM, 16 KB SRAM in RTC, Up to 8 MB PSRAM
- A 40 MHz crystal oscillator
- Reset and Boot push button
- Advanced USB-C type socket for flashing, and power supply
- External antenna for long range communication
- Additional CAN communication controller
- Easy-to-interface programming. Required no external debugger for flashing.
Getting started
...what's in the kit...
CAN bus information
Board Pinout
Flashing firmware
