ESP32-CAN-X2
ESP32-CAN-X2 is an innovative, and sophisticated development board that is specifically designed for CAN communication. This development board has all the features of a modern ESP32 development board, integrated Wi-Fi and Bluetooth, along with the extended CAN controller. AutosportsLabs has specifically designed it for advanced CAN communication along with fast processing and computation options. This is a complete how-to-use guide and this user guide will describe each and every step to use the board and harness the maximum potential of the board.
The prominent features of ESP32-CAN-X2 development board are as follows :
  • The development board is based on ESP32-SE-WROOM-1-N8R8 microcontroller powerful dual-core Xtensa LX6 CPU running at up to 240 MHz.
  • The development board has 384 KB ROM, 512 KB SRAM, 16 KB SRAM in RTC, 8 MB PSRAM
  • Two LED’s : LED PWM & LED communication
  • Reset and Boot push button
  • Integrated antenna for long range communication
  • 6-pin header is strategically positioned at the top for CAN communication
  • ESP32-CAN-X2 supports an additional external CAN transceiver
  • Integrated CAN transceivers
Getting started
...what's in the kit...
CAN bus information
Board Pinout
Flashing firmware
Sample Arduino Project
