ESP32-CAN-X2
ESP32-CAN-X2 is an innovative, and sophisticated development board that is specifically designed for CAN communication. This development board has all the features of a modern ESP32 development board, integrated Wi-Fi and Bluetooth, along with the extended CAN controller. AutosportsLabs has specifically designed it for advanced CAN communication along with fast processing and computation options. This is a complete how-to-use guide and this user guide will describe each and every step to use the board and harness the maximum potential of the board.
The prominent features of ESP32-CAN-X2 development board are as follows :
  • The development board is based on ESP32-SE-WROOM-1-N8R8 microcontroller powerful dual-core Xtensa LX6 CPU running at up to 240 MHz.
  • The development board has 384 KB ROM, 512 KB SRAM, 16 KB SRAM in RTC, 8 MB PSRAM
  • Two LED’s : LED PWM & LED communication
  • Reset and Boot push button
  • Integrated antenna for long range communication
  • 6-pin header is strategically positioned at the top for CAN communication
  • ESP32-CAN-X2 supports an additional external CAN transceiver
  • Integrated CAN transceivers
Getting started
Figure 1
Microcontroller
As mentioned above, the ESP32-CAN-X2 Development Board is designed around the ESP32-S3-WROOM-1-N8R8 microcontroller in a 40-pin package. The connections between the development board and the microcontroller are simple and easy to understand. The majority of GPIO pins are directly connected with the external headers, SV1 & SV2, and some pins are reserved internal connections between the board and CAN controllers. The internal connections between the microcontroller and CAN controllers are shown in the CAN controller heading given below. The microcontroller pin layout is shown in Figure 2 given below.
Figure 2
External Connection Header
In addition to the microcontroller, external headers, SV1 & SV2, are the two other important components of this development board. SV1 is the left side dual row header and the SV2 is the right side dual row header. Both of these headers have 20 pins available for connection. These headers provide connections for GPIOs, power output, ground (GND), power input, and CAN communication pins. Both of these header pinouts have standard size, allowing users to connect them using jumper wires, a breadboard, or even solder wires permanently onto the development board. However, while doing the wire connection the customer must make sure that none of them get short circuit. The details regarding the pin's names, numbers, outputs, and functions are given in the Board Pinout section below.
CAN Controllers
Moving on, MCP215, the external connected CAN communication controller, and ESP-32 built-in CAN communication controller are two other vital components of this development board. The details of the controller and their connection are as follows.
  • Implements CAN V2.0B at 1 Mb/s.
  • Interrupt Output Pin with Selectable Enables
  • Low-Power CMOS Technology: - Operates from 2.7V-5.5V, 5 mA active current (typical), 1 μA standby current
The internal pinout connections between the CAN controllers and the microcontroller are as follows.
  • CAN 2: This is the externally connected controller and this controller CS, MOSI, CLK, and MISO are connected at pin numbers 1O10, 1011, 1012, and 1O13 respectively. The connections are shown in Figure 3 given below
Figure 3
6 pin JST-PH Connector
In addition to the 40 pinouts of the Header SV1 and SV2, the ESP32-CAN-X2 development board also provides an additional 6-pin connector header at the top of the board to supports CAN communication. This header makes CAN communication more versatile and robust. It CAN communication connection pinout details are given in the pinout section below.
USB-C Socket
As mentioned in the features above, the ESP32-CAN-X2 development board has one USB-C port. This port is used for multiple functions: it powers the board, allows programming, and facilitates serial communication both ways. However, it is important to note that when powering the board through the USB-C port, please ensure the voltage does not exceed 5V @ 2A or 3.3V @ 1A.
Board Layout
The mechanical board outline of this development board is extremely simple, and as per the international standards. This board mechanical board's physical dimensions are as follows :
  • Width  : 42.10 mm
  • Length : 72 mm
Figure 4
Power Ratings & Requirements
The temperature, voltage, power, and current rating & requirement of the ESP32-CAN-X2 development board are as follows.
Power Options
Pin Voltage
VIN Rating
Operating Current
Power Consumption
Operating Temperature
CAN bus information
Board Pinout
Flashing firmware
Sample Arduino Project
