ESP32-CAN-X2
- Reset and Boot push button
- Integrated CAN transceivers
Getting started
Microcontroller
External Connection Header
CAN Controllers
6 pin JST-PH Connector
USB-C Socket
Board Layout
- Width : 42.10 mm
- Length : 72 mm
Power Options
Pin Voltage
VIN Rating
Operating Current
Power Consumption
Operating Temperature
CAN bus information
Multimaster system
Lossless communication
Simple and cheap
Errorless communication
CAN network types
Data transmission
Board Pinout
| 5 | RX Pin | USART RX |
| 6 | TX Pin | USART TX |
| 7-20 | GPIO Pins | GPIO's |
| 1-11 | GPIO Pins | GPIO's |
| 12-13 | Vin | Voltage Input |
| 14-15 | 5V | 5 Voltage Output |
| 16-18 | GND | Ground |
| 19-20 | 12 Vin | 12 Voltage Input |
Top Header Pinout
| 4 | GND | Ground |
| 5 | CAN2H/2.7A | high-level signal for the first CAN channel |
Flashing Firmware
Hardware Components
- USB-C cable
Software Components
Step by step instruction
- Open Arduino Ide
- Go to File > Preferences
Json URL : ( )
- In the Board Manager search bar, type ESP-32-X2 and click on install to install the board
Flashing
Endless Opportunities
