MegaJolt Lite Jr.
V4 Current Features
- Analog auxiliary input to further correct ignition map
- Modern, easy to use, and customizable Windows-based Configuration/Tuning software Screenshots
- Fine-tune crank sensor position
System Diagram
Implementing a crank-fired ignition system is straightforward. Once you perform the necessary mechanical installation of the crank trigger wheel and sensor, the rest is a straightforward wiring process.
Software Screenshots
Main Screen
The main screen displays runtime data at a glance plus allows editing of the primary ignition map.
Interactive Tuning Window
You can interactively tune on the fly using the intuitive 3D tuning view.
Advance Correction
The Auxiliary input channel allows further adjustment of ignition advance on top of the base map. A typical use is to correct advance based on engine temperature, through the use of a temperature sensor, or react from a 0-5V signal provided by an external system.
Datalogging View
You can observe runtime data plotted against time, as well as save data to a log file for later viewing and analysis.
- Configuration software
Current Hardware
Version 4.x
Older hardware revisions
Version 3.x
- Choosing between MAP or TPS
- Downloads
- Kit assembly guide
- Operation Guide
- Vehicle installation guide
Version 2.x
Ancient History
