RaceCapturePro Lua Scripting Examples
Revision as of 06:43, 10 March 2014 by Brentp (talk | contribs) (added example of setting CAN message to virtual channel)
API Reference
Complete API Reference
  if getGpsSpeed() > 10 then
    startLogging()
  else
    stopLogging()
setTickRate(30)
 local arm = getGpio(0)
 local g = getAccel(1)
 if arm == 0 then
   stopLogging()
 if arm == 1 and g < 0.1 then
   startLogging()
    setGpio(0, 1)
  else
    setGpio(0, 0)
or
 if getAnalog(0) > 212 then
   setGpio(0, 1)
 else
   setGpio(0, 0)
Given:
  • RPM sensor on timer input 0
setTickRate(15)
	r = getTimerRpm(0)
Given:
  t = readAnalog(0)
  msg = {t}
  txCAN(1234, 0, msg)
Given:
  • creates a channel named "RPM" that logs at 10Hz
  • Sets tick rate to 10Hz
  • Receive a CAN message, with 100ms timeout
rpmId = addChannel("RPM", 10)
  id, ext, data = rxCAN(100)
    setChannel(rpmId, data[0])
