RaceCapturePro Lua Scripting Examples
API Reference
if getGpsSpeed() > 10 then
startLogging()
else
stopLogging()
setTickRate(30) function onTick() local arm = getGpio(0) local g = getAccel(1) if arm == 0 then stopLogging() end if arm == 1 and g < 0.1 then startLogging() end end
setGpio(0, 1)
else
setGpio(0, 0)
or
function onTick() if getAnalog(0) > 212 then setGpio(0, 1) else setGpio(0, 0) end
Given:
- RPM sensor on timer input 0
setTickRate(15) function onTick() r = getTimerRpm(0) if r > 5000 then setGpio(2,1) else setGpio(2,0) end if r > 6000 then setGpio(1,1) else setGpio(1,0) end if r > 7000 then setGpio(0,1) else setGpio(0,0) end end
Given:
t = readAnalog(0)
msg = {t}
txCAN(1234, 0, msg)
Given:
- creates a channel named "RPM" that logs at 10Hz
- Note, the channel "RPM" needs to exist in RaceCapture/Pro's known list of channels
- Sets tick rate to 10Hz
- Receive a CAN message, with 100ms timeout
rpmId = addChannel("RPM", 10)
id, ext, data = rxCAN(100)
setChannel(rpmId, data[0])
