RaceCapturePro Lua Scripting Examples
API Reference
if getGpsSpeed() > 10 then
startLogging()
else
stopLogging()
setTickRate(30) function onTick() local arm = getGpio(0) local g = getAccel(1) if arm == 0 then stopLogging() end if arm == 1 and g < 0.1 then startLogging() end end
setGpio(0, 1)
else
setGpio(0, 0)
or
assumed: fuel sensor is on Analog 0, scaled 0-100% LED connected to PWM 0. When fuel level drops below 10%, Analog/PWM output 0 will show 5v; 0v if fuel level is higher
function onTick() local p = 0 if getAnalog(0) < 10 then p = 100 end setPWMDutyCycle(0,p) end
Given:
- RPM sensor on timer input 0
Given:
t = readAnalog(0)
msg = {t}
txCAN(1234, 0, msg)
Given:
- creates a channel named "RPM" that logs at 10Hz
- Note, the channel "RPM" needs to exist in RaceCapture/Pro's known list of channels
- Sets tick rate to 10Hz
- Receive a CAN message, with 100ms timeout
rpmId = addChannel("RPM", 10)
id, ext, data = rxCAN(100)
setChannel(rpmId, data[0])
