RaceCapturePro Lua Scripting Examples
API Reference
setTickRate(30) function onTick() local arm = getGpio(0) local g = getAccel(1) if arm == 0 then stopLogging() end if arm == 1 and g < 0.1 then startLogging() end end
or
Enable an LED or accessory if fuel level drops below 10%
- Using PWM/Analog output
function onTick() local p = 0 if getAnalog(0) < 10 then p = 100 end setPWMDutyCycle(0,p) end
- Using GPIO in output mode
Given:
- RPM sensor on timer input 0
Given:
function onTick() t = readAnalog(0) msg = {t} txCAN(1234, 0, msg) end
Given:
- creates a channel named "RPM" that logs at 10Hz
- Note, the channel "RPM" needs to exist in RaceCapture/Pro's known list of channels
- Sets tick rate to 10Hz
- Receive a CAN message, with 100ms timeout
rpmId = addChannel("RPM", 10) setTickRate(10) function onTick() id, ext, data = rxCAN(100) if id ~= nil then setChannel(rpmId, data[0]) end end
