MegaJolt Lite Jr.
The Megajolt Lite Jr. (MJLJ) is a fully configurable, stand-alone ignition controller designed to control a Ford EDIS 4, 6 or 8 crank-fired ignition module. It is an ideal ignition solution for carburated engines; it can also work in conjunction with compatible EFI systems. It is well supported with sophisticated yet easy to use Configuration Software.
Current Features
- Modern, easy to use, and customizable Windows-based configuration software
- Load, configure and save Ignition Configuration
New with V2.7.x/V3.1.0 beta
- TPS / Load axis calibration
- Improved user outputs with hysteresis
- Configuration software
Current Hardware
Version 3.x
- Choosing between MAP or TPS
- Downloads
- Kit assembly guide
- Vehicle installation guide
Older hardware revisions
Version 2.x
Ancient History
