RaceCapturePro Lua Scripting Examples
API Reference
Complete API Reference
  startLogging()
  if getGpsSpeed() > 10 then
    startLogging()
  else
    stopLogging()
setTickRate(30)
 local arm = getGpio(0)
 local g = getAccel(1)
 if arm == 0 then
   stopLogging()
 if arm == 1 and g < 0.1 then
   startLogging()
    setGpio(0, 1)
  else
    setGpio(0, 0)
or
 if getAnalog(0) > 212 then
   setGpio(0, 1)
 else
   setGpio(0, 0)
  • Using PWM/Analog output
 local p = 0
 setPWMDutyCycle(0,p)
  • Using GPIO in output mode
 local p = 0
 setGpio(0, p)
Given:
  • RPM sensor on timer input 0
setTickRate(15)
	local r = getTimerRpm(0)
Given:
  • CAN1 channel is used
  t = readAnalog(0)
  msg = {t}
  txCAN(0, 1234, 0, msg)
Given:
  • creates a channel named "RPM" that logs at 10Hz
    • Note, the channel "RPM" needs to exist in RaceCapture/Pro's known list of channels
  • Sets tick rate to 10Hz
rpmId = addChannel("RPM", 10)
  id, ext, data = rxCAN(0, 100)
    setChannel(rpmId, data[1])
Gear Calculation
local 1stGear = 3.5
local 2ndGear = 2.7
local 3rdGear = 2.0
local 4thGear = 1.4
local 5thGear = 0.9
local FinalDrive = 3.21
--diameter in inches
local TireDia = 25.0
local gearErr = 0.1
local rpmSpeedRatio = 0
local speed = getGpsSpeed()
local rpm = getTimerRpm(0)
gearId = addChannel("Gear",5)
if speed > 10 then
    if ((1stGear - rpmSpeedRatio)^2) < (gearErr^2) then gearPos = 1 end
    if ((2ndGear - rpmSpeedRatio)^2) < (gearErr^2) then gearPos = 2 end
    if ((3rdGear - rpmSpeedRatio)^2) < (gearErr^2) then gearPos = 3 end
    if ((4thGear - rpmSpeedRatio)^2) < (gearErr^2) then gearPos = 4 end
    if ((5thGear - rpmSpeedRatio)^2) < (gearErr^2) then gearPos = 5 end
else gearPos = 0 end
