RaceCapturePro Lua Scripting Examples
Revision as of 00:08, 13 February 2016 by Brentp (talk | contribs)
API Reference
Complete API Reference
Data filtering
Simple RPM Filter
rpmLimit = 10000
rpmId = addChannel( "RPM", 10, 0, 0, 10000, "RPM")
rpm = 0
function doRPM()
  local r = getTimerRpm(0)
  if r < rpmLimit then
    rpm = r
  setChannel(rpmId, rpm)
  doRPM()
Automatic logging control
  startLogging()
  if getGpsSpeed() > 10 then
    startLogging()
  else
    stopLogging()
  • System battery voltage is tied to the last Analog channel (7)
  if getAnalog(7) > 13 then
    startLogging()
  else
    stopLogging()
 setTickRate(30)
  local arm = getGpio(0)
  local g = getAccel(1)
  if arm == 0 then
    stopLogging()
  if arm == 1 and g < 0.1 then
    startLogging()
--10Hz update
--Create channel: "SensorAvg"
--Sample rate: 10Hz
--min/max: 0/5
--Units: "Volts"
  local a1 = getAnalog(0)
  local a2 = getAnalog(1)
Alerts/Notifications
Create an over-rev marker
  local rpm = getTimerRpm(0)
  local overRev = 0
Given:
--onTick() is called at 10Hz
rpmThreshold = 2000
lowOilPressure = 15
  local shockDriver = 0
    shockDriver = 1
  setGpio(0, shockDriver)
Track Max RPM / Value
maxRpm = 0
  if rpm > maxRpm then
    maxRpm = rpm
    setChannel(maxRpmId, maxRpm)
    setGpio(0, 1)
  else
    setGpio(0, 0)
or
 if getAnalog(0) > 212 then
   setGpio(0, 1)
 else
   setGpio(0, 0)
Multi warning light
   setGpio(0, 1)
 else
   setGpio(0, 0)
  • Using PWM/Analog output
 local p = 0
 setPwmDutyCycle(0,p)
  • Using GPIO in output mode
 local p = 0
 setGpio(0, p)
Given:
  • RPM sensor on timer input 0
setTickRate(15)
CAN bus scripts
Given:
  • CAN1 channel is used
  t = getAnalog(0)
  msg = {t}
  txCAN(0, 1234, 0, msg)
setTickRate(30) --30Hz
        id, e, data = rxCAN(0)
		print(id ..':')
		for i=1,#data do
			print(data[i] ..' ')
		println('')
    until id == nil
Given:
  • Sets tick rate to 10Hz
  id, ext, data = rxCAN(0, 100)
Gear Calculation
local _1stGear = 3.5
local _2ndGear = 2.7
local _3rdGear = 2.0
local _4thGear = 1.4
local _5thGear = 0.9
local FinalDrive = 3.21
--diameter in inches
local TireDia = 25.0
local gearErr = 0.1
local rpmSpeedRatio = 0
local speed = getGpsSpeed()
gearId = addChannel("Gear",5)
if speed > 10 then
    if ((_1stGear - rpmSpeedRatio)^2) < (gearErr^2) then gearPos = 1 end
    if ((_2ndGear - rpmSpeedRatio)^2) < (gearErr^2) then gearPos = 2 end
    if ((_3rdGear - rpmSpeedRatio)^2) < (gearErr^2) then gearPos = 3 end
    if ((_4thGear - rpmSpeedRatio)^2) < (gearErr^2) then gearPos = 4 end
    if ((_5thGear - rpmSpeedRatio)^2) < (gearErr^2) then gearPos = 5 end
else gearPos = 0 end
Miscellaneous
Simulating Laps
--use this script
et = 0 --ElapsedTime value
lt = 0 --LapTime value
pt = 0 --PredTime value
cl = 0 --CurrentLap value
lc = 0 --LapCount value
--completed a lap
if lc > 0 then
 pt = targetTime + rnd
 setChannel(ptid, pt)
et = et + 0.00166666667
setChannel(etid, et)
if et > targetTime + rnd then
 lt = et
 setChannel(ltid, lt)
 et = 0
 cl = cl + 1
 setChannel(clid, cl)
 if cl > 1 then
  lc = lc + 1
  setChannel(lcid, lc)
