RaceCapturePro Lua Scripting Examples
API Reference
Data filtering
Simple RPM Filter
--sample RPM at 10Hz
rpmLimit = 10000
rpm = 0
function doRPM()
local r = getTimerRpm(0)
if r < rpmLimit then
rpm = r
setChannel(rpmId, rpm)
doRPM()
Automatic logging control
if getGpsSpeed() > 10 then
startLogging()
else
stopLogging()
- System battery voltage is tied to the last Analog channel (7)
if getAnalog(7) > 13 then
startLogging()
else
stopLogging()
setTickRate(30)
local arm = getGpio(0)
local g = getAccel(1)
if arm == 0 then
stopLogging()
if arm == 1 and g < 0.1 then
startLogging()
--10Hz update
--Create channel: "SensorAvg"
--Sample rate: 10Hz
--min/max: 0/5
--Units: "Volts"
local a1 = getAnalog(0)
local a2 = getAnalog(1)
Alerts/Notifications
Create an over-rev marker
local rpm = getTimerRpm(0)
local overRev = 0
Given:
--onTick() is called at 10Hz
rpmThreshold = 2000
lowOilPressure = 15
local shockDriver = 0
shockDriver = 1
setGpio(0, shockDriver)
Track Max RPM / Value
maxRpm = 0
if rpm > maxRpm then
maxRpm = rpm
setChannel(maxRpmId, maxRpm)
setGpio(0, 1)
else
setGpio(0, 0)
or
Multi warning light
- Using PWM/Analog output
- Using GPIO in output mode
Given:
- RPM sensor on timer input 0
CAN bus scripts
Given:
- CAN1 channel is used
t = getAnalog(0)
msg = {t}
txCAN(0, 1234, 0, msg)
setTickRate(30) --30Hz
id, e, data = rxCAN(0)
print(id ..':')
for i=1,#data do
print(data[i] ..' ')
println('')
until id == nil
Given:
- Sets tick rate to 10Hz
id, ext, data = rxCAN(0, 100)
Gear Calculation
local _1stGear = 3.5
local _2ndGear = 2.7
local _3rdGear = 2.0
local _4thGear = 1.4
local _5thGear = 0.9
local FinalDrive = 3.21
--diameter in inches
local TireDia = 25.0
local gearErr = 0.1
local rpmSpeedRatio = 0
local speed = getGpsSpeed()
gearId = addChannel("Gear",5)
if speed > 10 then
if ((_1stGear - rpmSpeedRatio)^2) < (gearErr^2) then gearPos = 1 end
if ((_2ndGear - rpmSpeedRatio)^2) < (gearErr^2) then gearPos = 2 end
if ((_3rdGear - rpmSpeedRatio)^2) < (gearErr^2) then gearPos = 3 end
if ((_4thGear - rpmSpeedRatio)^2) < (gearErr^2) then gearPos = 4 end
if ((_5thGear - rpmSpeedRatio)^2) < (gearErr^2) then gearPos = 5 end
else gearPos = 0 end
Miscellaneous
Simulating Laps
--use this script
et = 0 --ElapsedTime value
lt = 0 --LapTime value
pt = 0 --PredTime value
cl = 0 --CurrentLap value
lc = 0 --LapCount value
--completed a lap
if lc > 0 then
pt = targetTime + rnd
setChannel(ptid, pt)
et = et + 0.00166666667
setChannel(etid, et)
if et > targetTime + rnd then
lt = et
setChannel(ltid, lt)
et = 0
cl = cl + 1
setChannel(clid, cl)
if cl > 1 then
lc = lc + 1
setChannel(lcid, lc)
