AutomaticCameraControl
GoPro WiFi control
This guide enables automatic start / stop control of WiFi enabled GoPro cameras using a speed based trigger.
When WiFi is enabled on your GoPro camera it creates a network that other devices can connect to. RaceCapture/Pro with the optional WiFi module can connect to this network and issue the appropriate commands to control various camera functions - in this case, starting and stopping video recording.
Starting and stopping the GoPro can controlled by a variety of means: speed, RPM or based on other sensor data - provided by a Lua Script running on RaceCapture/Pro. This guide focuses on using GPS speed to trigger the camera; for triggering on other sensors see the Lua scripting guide as a reference for what other sensor data is available.
Requirements
- RaceCapture/Pro MK2 running firmware 2.9.1 or higher
- RaceCapture/Pro WiFi module
- WiFi enabled GoPro Hero camera, with WiFi activated
- GPS Connectivity (for speed measurement)
Steps
Upgrade your firmware
Upgrade to the latest firmware if necessary. This guide was developed with firmware version 2.9.1.
Configure your GoPro
Connect the WiFi module
Connect the RaceCapture/Pro WiFi module to the outermost port of RaceCapture/Pro. When powered up, you should see the power LED illuminate.
Steps:
- Connect RaceCapture/Pro to the RaceCapture app and read the current configuration.
- Copy the Lua script into the Scripting window:
- Ensure the script window is first blank by removing the default script by deleting the text in the window.
- Note: If you have an existing script you want to keep, you will need to blend the camera functionality with your existing script. How to do this is beyond the scope of this guide; see the Lua Scripting Guide for more information.
- Copy the script into the window by using the ctrl-v keyboard shortcut.
- Write the configuration back to RaceCapture/Pro.
Bench testing
- Tip 1 Click the Poll Log to see the current message in the RaceCapture/Pro log
- Tip 2 To restart the Lua script, touch or click the 'Restart' button.
[GoProWiFi] start GoPro [GoProWiFi] stop GoPro
Road testing
- Drive carefully above the speed threshold and observe the GoPro - you should hear and see the familiar beep and red light activate, just as if you manually started recording using the shutter button on the camera.
- When you drop below the threshold, the GoPro should stop recording.
- GoPro WiFi network name (SSID) and password: Ensure the name and password currently in the script matches how your GoPro was configured.
- Enable WiFi on the GoPro: The blue LED on the GoPro should be blinking periodically
- RaceCapture/Pro WiFi module connection: Ensure the module is plugged into the outermost RJ11 port and the green LED is illuminated.
- Verify WiFi connection: Ensure RaceCapture/Pro can connect to the GoPro WiFi network. You should see the following messages in the log upon power-up:
[lua] Successfully loaded script. [GoProWiFi] initializing [GoProWiFi] ready for GoPro
[GoProWiFi] initializing [GoProWiFi] could not connect to GoPro [GoProWiFi] initializing [GoProWiFi] could not connect to GoPro [GoProWiFi] initializing [GoProWiFi] could not connect to GoPro [GoProWiFi] initializing
Lua Script
Customization
Required
- GoPro WiFi password: Specify the WiFi password used for the GoPro WiFi adapter
- GoPro SSID: Specify the GoPro WiFi network name (SSID)
Optional
- goproStart: Change this if you want to start recording at a different threshold.
- goproStop: Change this if you want to stop recording at a different threshold. Ensure this is less than the start trigger
- tickRate: Adjust this to update how often you want RaceCapture/Pro to perform a start/stop check. Value is in Hz. If uncertain, leave this alone
- debug: If things aren't working as expected you can set this to 1 to see the conversation between the WiFi module and the GoPro.
- This information shows up in the log window below the script window - check the box Poll log to see this information.
goproPwd = '12345678'
goproSsid = 'aslhero1'
goproStart = 10
goproStop = 5
--How fast we check, in Hz
tickRate = 10
debug = 0
--DO NOT EDIT BELOW
port = 4
--indicates wifiStatus
wifiStatus = 0
lastInitTime = 0
initTimeout = 20000
function logMsg(msg)
println('[GoProWiFi] ' ..msg)
function sendCrlf()
writeCSer(port, 13)
writeCSer(port, 10)
function sendRaw(val)
for i=1, #val do
function sendAt(val)
sendRaw(val)
sendCrlf()
function toInt(val)
return string.sub(val, 1, -3)
function httpGet(url)
sleep(500)
sleep(100)
sendRaw(get)
sleep(100)
sendAt("AT+CIPCLOSE")
function startGoPro()
logMsg('start GoPro')
sendGoProShutter('01')
function stopGoPro()
logMsg('stop GoPro')
sendGoProShutter('00')
recording = 0
function initWiFi()
logMsg('initializing')
sendAt('AT+RST')
sleep(2000)
sendAt('AT+CWMODE_CUR=1')
sleep(1000)
wifiStatus = 1
function processIncoming()
wifiStatus = 2
wifiStatus = 3
logMsg('ready for GoPro')
function checkGoPro()
if wifiStatus == 0 then
initWiFi()
lastInitTime = getUptime()
return
wifiStatus = 0
processIncoming()
if wifiStatus ~= 3 then
return
trigger = getGpsSpeed()
startGoPro()
recording = 1
stopGoPro()
recording = 0
checkGoPro()
