AutomaticCameraControl
Revision as of 19:18, 24 December 2016 by Brentp (talk | contribs)
GoPro WiFi control
This guide shows you how to enable automatic start / stop control of WiFi enabled GoPro cameras using RaceCapture/Pro.
When WiFi is enabled on your GoPro camera it creates a network that other devices can connect to. RaceCapture/Pro with the optional WiFi module can connect to this network and issue the appropriate commands to control various camera functions - in this case, starting and stopping video recording.
Starting and stopping the GoPro can be controlled by a variety of means: speed, RPM or based on other sensor data, enabled by a Lua Script running on RaceCapture/Pro.
Notes
  • Currently, the WiFi module can only be used to enable GoPro triggering.
  • If running firmware version 2.10.x or higher To use this script, you must disable the built-in WiFi control, or else it will take over the connection and block the script from running.
  • Future versions of RaceCapture firmware and app will allow built-in firmware control of GoPro cameras, which will eliminate the need for this script.
Requirements
  • RaceCapture/Pro WiFi module
  • WiFi enabled GoPro Hero camera, with WiFi activated
  • GPS Connectivity (for speed measurement)
Steps
Upgrade your firmware
Upgrade to the latest firmware if necessary. This guide was developed with firmware version 2.9.1.
Configure your GoPro
Connect the WiFi module
  • When powered up, you should see the power LED illuminate.
  • This port is to the right of the Bluetooth Port.
    • The WiFi module does not interfere with the operation of the Bluetooth module.
Steps:
Bench testing
  • Tip 1: Touch or click the Poll Log to see the current message in the RaceCapture/Pro log
  • Tip 2: To restart the Lua script, touch or click the 'Restart' button.
Road testing
  • Drive carefully above the speed threshold and observe the GoPro - you should hear and see the familiar beep and red light activate, just as if you manually started recording using the shutter button on the camera.
  • When you drop below the threshold, the GoPro should stop recording.
[GoProWiFi] start GoPro
[GoProWiFi] stop GoPro
  • GoPro WiFi network name (SSID) and password: Ensure the name and password currently in the script matches how your GoPro was configured.
  • Enable WiFi on the GoPro: The blue LED on the GoPro should be blinking periodically
  • RaceCapture/Pro WiFi module connection: Ensure the module is plugged into the outermost RJ11 port and the green LED is illuminated.
  • Verify WiFi connection: Ensure RaceCapture/Pro can connect to the GoPro WiFi network. You should see the following messages in the log upon power-up:
[lua] Successfully loaded script.
[GoProWiFi] initializing
[GoProWiFi] ready for GoPro
[GoProWiFi] could not connect to GoPro
Lua Script
Customization
Required
Optional
goproPwd = '12345678'
goproSsid = 'aslhero1'
goproStart = 10
goproStop = 5
--How fast we check, in Hz
tickRate = 10
debug = 0
--DO NOT EDIT BELOW
port = 4
--indicates wifiStatus
wifiStatus = 0
lastInitTime = 0
initTimeout = 20000
function logMsg(msg)
  println('[GoProWiFi] ' ..msg)
function sendCrlf()
  writeCSer(port, 13)
  writeCSer(port, 10)
function sendRaw(val)
  for i=1, #val do
function sendAt(val)
  sendRaw(val)
  sendCrlf()
function toInt(val)
  return string.sub(val, 1, -3)
function httpGet(url)
  sleep(500)
  sleep(100)
  sendRaw(get)
  sleep(100)
  sendAt("AT+CIPCLOSE")
function startGoPro()
  logMsg('start GoPro')
  sendGoProShutter('01')
function stopGoPro()
  logMsg('stop GoPro')
  sendGoProShutter('00')
recording = 0
function initWiFi()
  logMsg('initializing')
  sendAt('AT+RST')
  sleep(2000)
  sendAt('AT+CWMODE_CUR=1')
  sleep(1000)
  wifiStatus = 1
function processIncoming()
    wifiStatus = 2
    wifiStatus = 3
    logMsg('ready for GoPro')
function checkGoPro()
  if wifiStatus == 0 then
    initWiFi()
    lastInitTime = getUptime()
    return
    wifiStatus = 0
  processIncoming()
  if wifiStatus ~= 3 then
    return
  trigger = getGpsSpeed()
    startGoPro()
    recording = 1
    stopGoPro()
    recording = 0
  checkGoPro()
