RaceCapture DashWare Guide
Record and save data on RCP
- Open the log file in Excel, go to Data > Convert Text to Columns > Use comma for the separator
If you need more info or would like to create your own Dashware Data Profile, please see Step 3 of Rowan Hicks excellent guide here. https://www.rowanhick.com/2016/01/07/racecapture-pro-dashware-win
Fix your video file if needed
