MegaJolt Lite Jr.
Revision as of 21:35, 21 March 2018 by Brentp (talk | contribs) (Brentp moved page Megajolt E to MegaJolt Lite Jr.: MegaJolt Lite Jr.)
V4 Quick Links
Quick Links
Hard Rev Limiter
An external module which provides hard rev limiting capabilities, triggered by the rev limiter output of the MegaJolt Lite Jr.
V4 Current Features
  • Analog auxiliary input to further correct ignition map
  • External Rev-Limit trigger output (The Ford EDIS module has no 'rev limit' signal, so an external circuit to disable the ignition coil is required)
  • Modern, easy to use, and customizable Windows-based Configuration/Tuning software Screenshots
  • Fine-tune crank sensor position
    • Load, modify and save Ignition Configuration
System Diagram
Implementing a crank-fired ignition system is straightforward. Once you perform the necessary mechanical installation of the crank trigger wheel and sensor, the rest is a straightforward wiring process.
Software Screenshots
Main Screen
The main screen displays runtime data at a glance plus allows editing of the primary ignition map.
Interactive Tuning Window
You can interactively tune on the fly using the intuitive 3D tuning view.
Advance Correction
The Auxiliary input channel allows further adjustment of ignition advance on top of the base map. A typical use is to correct advance based on engine temperature, through the use of a temperature sensor, or react from a 0-5V signal provided by an external system.
Datalogging View
You can observe runtime data plotted against time, as well as save data to a log file for later viewing and analysis.
Current Hardware
Version 4.x
Older hardware revisions
Version 3.x
Version 2.x
Ancient History
