RaceCapture-Track MK2
Start it up
Plug it in
  • Plug one end of the OBDII cable into the RaceCapture RJ45 port.
Mounting
Place the RaceCapture system on a level surface in your car, with the connectors facing forward and logo up. This is the factory orientation for the accelerometers and gyro.
Attach GPS
Locating Antenna
  • Ideal: Mount the antenna on the roof of the vehicle, using the magnetic mount. Place the antenna with minimum 3 feet spacing from other transmitting antennas (car radios, cellular antennas, etc).
  • Alternate Mounting: You can mount it on the dashboard in clear view of the sky, or on the rear parcel tray under the back window. Note, this may degrade your GPS performance vs. roof mounting.
Download the app
First Time Setup
Android
We recommend connecting with Bluetooth when using Android devices.
Connecting with Bluetooth
  • Ensure RaceCapture is powered.
    • The default password is 1234 - you can change this later under Setup.
Connecting with WiFi
  • Under Android settings, navigate to the WiFi section.
  • Wait until you see the RaceCapture WiFi network.
  • Select this network to connect.
    • Note No password is required for the initial connection - you can set a password for your WiFi network later under Setup.
iOS
  • Under your iOS settings, navigate to the WiFi section.
Launching the first time Setup
Navigating dashboard screens
Setup Mode
Explanation of buttons
Enabling Telemetry
Notes about Android devices
Analysis
Navigating data
Selecting time vs distance
RaceRender
Applying Decals
More
Alternative ways to power
USB
Custom Cable
Connection RaceCapture/Track MK2 (RJ45 cable)
+12v Brown
Ground Orange/White
CAN 1 High Orange
CAN 1 Low Green/White
CAN 2 High Blue
CAN 2 Low Blue/White
Steps to recover:
  • Connect RaceCapture via USB
