RaceCapture-Track
Revision as of 17:25, 25 October 2026 by Brentp (talk | contribs) (→RaceCapture software on Windows / OSX)
Start it up
Plug it in
Download the app
LED status
  • * Very fast green flash': Very rapid green flash indicates the unit is in bootloader mode, during firmware updates. If you see this when the the unit powers up and you cannot connect with the RaceCapture app, it usually means a failed firmware upgrade. You can resolve the issue by going through the firmware update process again.
  • Blue : WiFi activity
  • Red: Firmware error
Navigating dashboard screens
Setup Mode
Explanation of buttons
Enabling Telemetry
Notes about Android devices
Logs
Analysis Mode
Navigating data
Selecting time vs distance
RaceRender
Updating Firmware
More
Alternative ways to power
USB
Custom Cable
+12v Brown
Ground Orange/White
CAN 1 High Orange
CAN 1 Low Green/White
Steps to recover:
  • Connect RaceCapture via USB
