RaceCapturePro Lua Scripting Examples
API Reference
OBDII tricks
Clear current trouble codes
setTickRate(1)
count = 0
checkClearCodes()
function checkClearCodes()
if count % 10 == 0 then
print('clearing codes')
txCAN(0, 0x7df, 0, {1,4})
setTickRate(1)
prefixes = {'P','C','B','U'}
function toDigit(v)
return digits[v+1]
function printDTC(data)
local dtc
local a = data[3]
local b = data[4]
local c3 = bit.band(a, 0x0f)
local c5 = bit.band(b, 0x0F)
println('Found DTC: ' ..code)
function printRawDTC(data)
print('Raw DTC bytes: ')
println('')
function checkDTCResponse()
local attempts = 0
while attempts < 50 do
if data[2] == 0x43 then
if data[1] > 2 then
printRawDTC(data)
printDTC(data)
else
println('No DTC Found')
return
attempts = attempts + 1
function sendCheckDTC()
println('Sending check DTC')
txCAN(0, 0x7df, 0, {1,3})
sendCheckDTC()
checkDTCResponse()
Display OBDII Codes as a channel and allow driver to reset the OBDII Codes with a button
tickRate = 5
counter=0
OBDCodes = {'-1'}
currCode = 1
function clearOBDCodes()
for i=#OBDCodes, 1, -1 do
OBDCodes[i] = nil
OBDCodes[1] = '-1'
function addOBDCode(code)
local codeFound = false
for i=1, #OBDCodes do
if not codeFound then
OBDCodes[#OBDCodes+1] = code
function displayOBDCodes()
counter = counter+1
currCode = currCode+1
counter = 0
clearOBDCodes()
function toDigit(v)
return digits[v+1]
local dtc
local a = data[3]
local b = data[4]
addOBDCode(code)
code = prefix ..code
a = data[5]
b = data[6]
local d3 = bit.band(a, 0x0f)
local d5 = bit.band(b, 0x0F)
addOBDCode(code2)
code2 = prefix ..code2
a = data[7]
b = data[8]
local e3 = bit.band(a, 0x0f)
local e5 = bit.band(b, 0x0F)
addOBDCode(code3)
code3 = prefix ..code3
println('')
local attempts = 0
if data[1] > 2 then
printRawDTC(data)
printDTC(data)
else
--println('No DTC Found')
return
checkDTCResponse(1)
displayOBDCodes()
checkClearCodes(1)
Data filtering
Simple RPM Filter
--sample RPM at 10Hz
rpmLimit = 10000
rpm = 0
function doRPM()
local r = getTimerRpm(0)
if r < rpmLimit then
rpm = r
setChannel(rpmId, rpm)
doRPM()
Automatic logging control
if getGpsSpeed() > 10 then
startLogging()
else
stopLogging()
if getAnalog(8) > 13 then
startLogging()
else
stopLogging()
setTickRate(30)
local arm = getGpio(0)
local g = getAccel(1)
if arm == 0 then
stopLogging()
if arm == 1 and g < 0.1 then
startLogging()
maxAvg = 600
--do not change
fuelAvg={}
fuel2Index = 1
function updateFuelAvg(value)
local i
if #fuelAvg == 0 then
--initialize averaging table
fuelAvg[fuel2Index] = value
fuel2Index = fuel2Index + 1
local sum = 0
for i = 1, #fuelAvg do
sum = sum + fuelAvg[i]
setTickRate(30)
updateFuelAvg(getAnalog(0))
--10Hz update
--Create channel: "SensorAvg"
--Sample rate: 10Hz
--min/max: 0/5
--Units: "Volts"
local a1 = getAnalog(0)
local a2 = getAnalog(1)
Gear Calculation
setTickRate(30)
--create gear channel
setChannel(gearId,gear)
Also available as a preset
Throttle Position Calculation
MaxAccelG = 0.30 -- Look at your logs and see what your max acceleration is in 3rd or 4th gear. Note that full acceleration in 5th will not show 100% throttle.
function updatevThrottle()
TPS = (AccelG/MaxAccelG)*100
if TPS < 0 then TPS = 0 end
TPS = math.abs(TPS)
setChannel(chThrottle, TPS)
--10Hz update
updatevThrottle()
Brake Position Calculation
MaxDecelG = 1.20 --Look at your logs and see what your maximum g-forces under straight line braking is and round down.
function updatevBrake()
--if ReverseAccel then
BrakeG = BrakeG *-1
--BrakeG = -1.1
BrakePos = math.abs(BrakePos)
setChannel(chBrake, BrakePos)
--10Hz update
updatevBrake()
maxRpm = 0
function rpmReset()
local rpm = getTimerRpm(0)
local clear = getGpio(0)
if rpm > maxRpm then
maxRpm = rpm
setChannel(maxRpmId, maxRpm)
if clear == 0 then
maxRpm = 0
rpmReset()
Alerts/Notifications
Create an over-rev marker
Given:
local rpm = getChannel("RPM")
Create an Impact marker
if gsum ~= nil and gsum > 2.0 then --Assumes anything over 2.0G's is an impact. Change to suit your needs.
function updateDiffSwitch()
if diffTemp ~=nil and diffTemp > 180 then --update temp to turn on at
setGpio(2,1)
setGpio(2,0) --Uses GPIO3 for output. Increase SampleRate or TickRate if it isn't turning on
Given:
--onTick() is called at 10Hz
rpmThreshold = 2000
lowOilPressure = 15
local shockDriver = 0
shockDriver = 1
setGpio(0, shockDriver)
Track Max RPM / Value
maxRpm = 0
maxRpm = rpm
setGpio(0, 1)
else
setGpio(0, 0)
or
Multi warning light
- Using PWM/Analog output
- Using GPIO in output mode
Given:
- RPM sensor on timer input 0
ProFormance Meter
setTickRate(25)
sxSetConfig(1)
yawThreshold = 25 --At what yaw rate do you want the oversteer alarm lights to trigger' Check normal max yaw on your Podium.live race summaries to get a better idea of what value you should use
maxGsum = .3
maxLatG = .2
maxBrakeG = .2
maxAccelG = .1
currLatG = 0
longG = 0
lastLongG = 0
lastLatG = 0
function updateGStats()
if gsum > maxGsum then
maxGsum = gsum
if latG ~= nil then
latG = math.abs(latG)
if latG > maxLatG then
maxLatG = latG
if currLongG ~= nil then
if currLongG>0 then
if currLongG > maxBrakeG then
maxBrakeG = currLongG
elseif currLongG<0 then
if currLongG>maxAccelG then
maxAccelG = currLongG
function alertYaw(Yaw) --Light up the side ShiftX lights in case of an Oversteer event
sxSetLed(7,2,255,255,255,9)
sxSetLed(7,2,255,255,255,5)
sxSetLed(7,2,255,255,255,3)
else
sxSetLed(7,2,0,0,0,0)
sxSetLed(0,0,0,0,0,0)
local cLongG = getChannel("AccelX")
if cLongG ~= nil then
longG = cLongG
local BrakeAccel = "Braking"
local maxLongG = maxBrakeG
--may not want to do this
-- maxLongG = maxAccelG
--end
local latGAvail = 0
local longGAvail = 0
latGAvail = maxLatG*(1-(currLongG/maxLongG))
else --Pro Driver
local percGUsedLat
if latGAvail <= 0 then
percGUsedLat = 1
else
local percGUsedLong
if longGAvail <= 0 then
percGUsedLong = 1
else
local ProFormanceRating
local TotalPot2
TotalPot2 = 1
else
local TotalPot3
TotalPot3 = 1
else
else
local TotalPot2
TotalPot2 = 1
else
local TotalPot3
TotalPot3 = 1
else
lastLongG = currLongG
lastLatG = currLatG
return ProFormanceRating
resetSxLeds()
sxSetLed(0,numLeds,255,0,0,0)
sxSetDisplay(0,rating)
resetSxLeds()
updateGStats()
local driverLevel = 1
collectgarbage()
CAN bus scripts
setTickRate(30)
id, ext, data = rxCAN(0)
if (id ~= nil) then
txCAN(1, id, ext, data)
Given:
- CAN1 channel is used
local speed = getGpsSpeed()
local msg = {speed}
txCAN(0, 1234, 0, msg)
Given:
local tmp = getAnalog(0)
local msg = {tmp}
setTickRate(30) --30Hz
id, e, data = rxCAN(0)
print(id ..':')
for i=1,#data do
print(data[i] ..' ')
println('')
until id == nil
Given:
- Sets tick rate to 10Hz
id, ext, data = rxCAN(0, 100)
CAN bus loopback test
Wiring / Setup
-- CAN loopback test
can_id = 1234
count = 0
count = count + 1
if id == nil then
else
Integrate with RaceVoice via CAN
RaceVoice integrates with your data logger to audibly tell you info like high engine temp, low oil pressure, overrev, low battery, wheel lockup warnings as well as Pit to Car messages. It can also tell you things like rolling MPH at the end of a straight, max g-forces through a turn, lap segment delta, lap times, etc in order to be a more consistent and faster driver. You can find a list of Race Voice Features here. Take a look at this video for more info.
Please note that Firmware 2.18 or greater is required for the Pit to Car messaging to work with RaceVoice.
tickRate = 10
TPS = 100
RPM = 0
Speed = 0
AccelY = 0
AccelX = 0
ECT = 0
OilP = 0
Volts = 0
BrakeP = 0
WheelSpdLF = 0
WheelSpdRF = 0
WheelSpdLR = 0
WheelSpdRR = 0
LapNum = 0
LapTime = 0
BestTime = 0
LapDelta = 0
Lat = 0
Long = 0
function split16(val)
function split32(val)
function txRVCANData(channel)
local lBrakeP = getChannel('Brake_F')
txCAN(channel, 0x5A, 0, {LapNum2, LapNum1, LapTime2, LapTime1, BestTime2, BestTime1, LapDelta2, LapDelta1})
txRVCANData(1) --0=CAN Channel 1; 1=CAN Channel 2
collectgarbage()
Serial Port
Read a line of serial data
value = readSer(4, 100)
if value ~= nil then
Demo Scripts
RPM Sweep
-- 05 Jan 2016 RPM demo
-- F.Mirandola - B.Picasso
thrRpmLo = 3000
thrRpmHi = 10000
incrementRpm = 300
-- Do not edit after this!!
rpm = 0
direction = 0
Simulating Laps
--use this script
et = 0 --ElapsedTime value
lt = 0 --LapTime value
pt = 0 --PredTime value
cl = 0 --CurrentLap value
lc = 0 --LapCount value
--completed a lap
if lc > 0 then
pt = targetTime + rnd
setChannel(ptid, pt)
et = et + 0.00166666667
setChannel(etid, et)
if et > targetTime + rnd then
lt = et
setChannel(ltid, lt)
et = 0
cl = cl + 1
setChannel(clid, cl)
if cl > 1 then
lc = lc + 1
setChannel(lcid, lc)
