Remote Coaching with Race Capture
Using telemetry data and live streaming video, coaches can use these tools to coach live remotely, either from the pits at the track or from the comfort of their home offices or just about anywhere. Autosport Labs Race Capture and Podium Connect devices stream data logging data to Podium.live website for instantaneous live telemetry data. This data can be viewed anywhere with a web browser or the Podium app. You can also use a cheap camera with a hotspot to stream live to YouTube. You can then add this live streaming video to your Podium event page to be able to see live streaming data and video in one place. You can use the live telemetry data to quickly find areas for improvement, and then use live video to quickly see what they are doing that needs improvement and communicate this feedback instantaneously to your student/client via cell phone.
Please note: YouTube live streams have around a 40 second delay, so you cannot use the video for live instructing. There is no delay in the data telemetry so you can analyze the data and video and when you see them coming up to the section in question on the live data again, you can tell them what to work on this time around.
- Race Capture/Track ($299)
- Yi 4K Action Camera ($99-199) (Must be Yi 4K, not Yi 4K+ or Yi Lite)
- MicroSD card ($6)
- 4G Hotspot with ~10GB/mo unrestricted/unthrottled data- Contact Eric Kaul at Verizon for the Motorsports/HPDE discount.
- 3 Port USB car charger ($10)
- (2) 6' micro USB cables ($5)
- [https://amzn.to/3d7F3xi 2" wide Velcro ($19)
- Bluetooth cellphone headset ($30)
- Android or iOS cellphone
Initial Setup
Race Capture Setup
- Under GPS settings, change to Imperial (mph and ft) units
- Under Wireless, make sure Bluetooth and Access Point Mode is On. You may want to change the Bluetooth name (under Advanced) and the WiFi SSID. This will require a full power off/on reboot to take effect.
- Be sure to add your DeviceID in the Telemetry settings
- Write your changes to the Race Capture device.
- Save your config file to your PC (this is important. config info is lost when updating firmware and must be reloaded from the file)
- Update your Firmware if a new version is available. Config data is lost when you upgrade firmware, so you will need to Open the config file you saved and then Write it to the Race Capture Track.
- Go to YouTube.
- From the top right, click Create and then Go live.
- For more info, see YouTube's instructions
Yi 4k Setup for auto streaming
- Download this zip file and copy the contents of the unzipped files onto a micro SD card.
