RaceCapturePro Downloads
RaceCapture App
- MK1 users: ensure you have updated to the latest V2 firmware.
Windows
Requirements: Windows 7+; 2GB RAM; OpenGL 2.0 graphics support
Note on OpenGL 2.0 requirements
- The app will fail to launch if OpenGL 2.0 graphics are not supported. If this happens try updating your graphics driver, or use a computer with updated graphics support.
Windows USB Driver
Windows 10:
- No drivers are needed for Windows 10. Windows will automatically detect RaceCapture/Pro, and it will appear as a USB Serial device under Device Manager.
Windows XP, 7, 8:
Mac OS X
Requirements: OSX 10.6+
Unzip the file and copy the RaceCapture app to your Applications directory.
Android
Android:
Google Play Store Download
Amazon App Store Download
iOS
IOS support coming in a future release.
Linux
Packages forthcoming; meanwhile run from source from the github repository
Firmware
RaceCapture/Pro MK2
RaceCapture Firmware Downloads
Installation instructions can be found in the zip archive.
Additional information
RaceCapture/Pro MK1
MK1 Bootloader Releases
Firmware update utility
