MegaJolt Lite Jr.
Revision as of 18:02, 2 July 2008 by Brentp (talk | contribs) (→Version 3.x: added operation guide for V3)
The Megajolt Lite Jr. (MJLJ) is a fully configurable, stand-alone ignition controller designed to control a Ford EDIS 4, 6 or 8 crank-fired ignition module. The result is a precision, digitally controlled distributorless ignition system.
Current Features
  • External Rev-Limit trigger output (The Ford EDIS module has no 'rev limit' signal, so an external circuit to disable the ignition coil is required)
  • Modern, easy to use, and customizable Windows-based configuration software
    • Load, modify and save Ignition Configuration
New with V2.8.x/V3.2.0
  • TPS / Load axis calibration
  • Improved user outputs with hysteresis
Current Hardware
Version 4.x
Version 3.x
Older hardware revisions
Version 2.x
Ancient History
