MegaJolt Lite Jr.
The Megajolt Lite Jr. (MJLJ) is a fully programmable, stand-alone ignition controller designed to control a Ford EDIS 4, 6 or 8 crank-fired ignition module. The result is a precision, digitally controlled distributorless ignition system.
V4 Current Features
- Analog auxiliary input to further correct ignition map
- Modern, easy to use, and customizable Windows-based Configuration/Tuning software Screenshots
- Fine-tune crank sensor position
Software Screenshots
Main Screen
The main screen displays runtime data at a glance plus allows editing of the primary ignition map.
Interactive Tuning Window
You can interactively tune the engine while running using the intuitive 3D tuning view.
Advance Correction
The Auxiliary input channel allows for further correction of ignition advance. A typical use is to correct advance based on engine temperature, through the use of a temperature sensor, or react from a 0-5V signal provided by an external system.
Datalogging View
You can observe runtime data plotted against time, as well as save data to a log file for later viewing and analysis.
- Configuration software
Current Hardware
Version 4.x
Version 3.x
- Choosing between MAP or TPS
- Downloads
- Kit assembly guide
- Operation Guide
- Vehicle installation guide
Older hardware revisions
Version 2.x
Ancient History
