MegaJolt Lite Jr.
V4 Current Features
  • Analog auxiliary input to further correct ignition map
  • External Rev-Limit trigger output (The Ford EDIS module has no 'rev limit' signal, so an external circuit to disable the ignition coil is required)
  • Modern, easy to use, and customizable Windows-based Configuration/Tuning software Screenshots
  • Fine-tune crank sensor position
    • Load, modify and save Ignition Configuration
Software Screenshots
Main Screen
The main screen displays runtime data at a glance plus allows editing of the primary ignition map.
Interactive Tuning Window
You can interactively tune on the fly using the intuitive 3D tuning view.
Advance Correction
The Auxiliary input channel allows further adjustment of ignition advance on top of the base map. A typical use is to correct advance based on engine temperature, through the use of a temperature sensor, or react from a 0-5V signal provided by an external system.
Datalogging View
You can observe runtime data plotted against time, as well as save data to a log file for later viewing and analysis.
Current Hardware
Version 4.x
Mjlj v4 preview case board perspective.jpgMjlj v4 board preview.jpgMjlj v4 preview map peeking.jpgMjlj v4 preview molex peeking.jpgMjlj v4 preview end installed.jpg
Version 3.x
MjljV3 MAP prebuilt.jpgMjlj v3 build step6 map.jpgMjlj v3 build step5 map.jpg
Older hardware revisions
Version 2.x
Mjlj v2 molex end.jpgMjlj v2 open case closeup2.jpgMjlj assembly complete.jpg
Ancient History
