RaceCapturePro Sensors
IMU (Accelerometer / Gyro)
Systems with an on-board IMU should be mounted in the default orientation, typically with the device connectors oriented towards the front of the vehicle.
- Note Check the model's documentation for the specific mounting guide.
Mounting in an alternate orientation
- Inverted mounting
- Flat / upright, but rotated 90 degrees
- On-edge, but aligned with the front-rear axis of the vehicle
Re-orientation requires re-mapping of the accelerometer channels, using the RaceCapture app
Re-orientation procedure
Preparation
Prior remapping, creata a temporary racecapture dashboard with the 6 channels (AccelX, AccelY, AccelZ, Yaw, Pitch, Roll)
Detach the system from the vehicle, and visually note the behavior of each channel by moving the system about in free air. See the diagram for reference:
Remapping channels
Now, hold the device in free air at the new orientation, and then swap / invert IMU channels using the RaceCapture app to attain the behavior seen with the default orientation and default channel mappings.
Zero Calibration
After orientation is updated (as needed) and the system is mounted to the vehicle, ensure the vehicle is on a level surface. Then, perform a final zero calibration by pressing the Calibrate button in the RaceCapture app. This will zero out all 6 axis. At this point you can perform a final write / save of your configuration
Pullup Resistor
Sensor Ground
- Thread Size : 1/8″ NPT
- Cable length : 1 Meter
- Voltage supply : 3-5V
- Thread Size : 3/8" NPT
- Cable length : N/A
- Body Material : Copper
- Pigtail :Pico 5616pt
- Body Material : Brass
- Voltage supply : 5V
- Datasheet :Click here
Pressure Sensors
- Cable length : 2 Meter
- Mfg / Prt : AEM 30-2131-150
- Data Sheet : Click here
- Mfg / Prt : 12223861 (GM)
- Output : 0.2 to 4.9 V
Pulse/Speed/RPM Sensors
- Power
- Ground
- Signal Output
Wiring the Speed Sensor
Recommended RPM Sensor
- Mfg / Prt : ASL_COILX
- Mfg / Prt : Hamlin 55505
- Datasheet : Click here
- Mfg / Prt : Cherry GS100701
- Thread Size : 15/32-32
- Supply Voltage : 5 to 24 V
- Supply Current : 3 to 6 mA
- Body Material : Aluminum
- Output current : 25mA max
Distance Sensors
[ASL_STRING_POT_M8 : 500mm string potentiometer sensor]
- Cable : 2 meter cable
- Range : 10K ohm range
[ Sharp GP2D12 : IR Range Sensor]
- Mfg / Prt : Sharp GP2D12
- Detecting Range : 10-80cm
[ BMW 37140141444 : Height Level Sensor]
- Mfg / Prt : BMW 37140141444
- Pigtail : 61138383300
- Voltage Supply : 5V
[ KA Sensors RHL3 : Laser Ride Height Sensor]
Step To Calibrate :
Create Calibration Table:
Angle/Rotation Sensors
[Ford / SMP TH45 : Throttle Position Sensor]
- Mfg/Prt : Ford / SMP TH45
- Pigtail : Pico 5752PT
- Supply Voltage : 5V
Fuel Level Sensor
Fuel level sensor calibration
- 0%
- 25%
- 50%
- 75%
- 100%
Smoothing the channel to deal with slosh
Alternative Fuel level senders
Fuel level senders with 0-5v signal output
Air/Fuel Ratio Sensor
[Texense LSU 4.9 : Air / Fuel Ratio Sensors]
- Mfg/Prt : Texense LSU 4.9
- Pigtail : Built-in wiring
Thermal Sensor
Recommended Thermal Sensors
[ASL_TIREX_4PACK / ASL_TIREX_SINGLE : TireX advanced thermal sensor ]
- Accuracy : 1C
- Supply voltage : 6 – 12v
- Power : 200mW
- Interface : CAN 2.0
SensorX sensor breakout board
- Dimensions: 0.4″ x 4″
- Five 2.2K resistors
Wiring Analog Sensors
Calibrating Analog Sensors
Linear Sensors
Example : 150 PSI pressure sensor
- 0.5 v = 0 PSI
- 4.5 v = 150 PSI
Curved Sensors
Example : Extended range temperature sensor with 5v reference and 2.2K pullup resistor
- 0.4 v = 302 F
- 0.87 v = 239 F
- 1.88 v = 176 F
- 3.2 v = 122 F
- 4.72 v = 32 F
Fuel Level Sensors
Calibration
- Empty (0%)
- 1/4 (25%)
- 1/2 (50%)
- 3/4 (75%)
- Full (100%)
Set up the Analog Channel
- Set the sample rate to 1Hz.
