Ford EDIS technical information
Revision as of 18:07, 25 July 2009 by Brentp (talk | contribs) (moving info to "trigger wheel designs")
Ford EDIS general information
Sensor Position
Type Degrees BTDC
EDIS-4 90
EDIS-6 60
EDIS-8 50
Interfacing with OEM Tach
Tach circuit
Trigger Wheel Designs
Adapting OEM trigger wheel
Alternate coil wiring
