RaceCapturePro Lua Scripting Examples
Revision as of 19:59, 9 March 2014 by Brentp (talk | contribs)
  if getGpsSpeed() > 10 then
    startLogging()
  else
    stopLogging()
setTickRate(30)
 arm = getGpio(0)
 g = getAccel(1)
 if arm == 0 then
   stopLogging()
 if arm == 1 and g < 0.1 then
   startLogging()
    setGpio(0, 1)
  else
    setGpio(0, 0)
or
 if getAnalog(0) > 212 then
   setGpio(0, 1)
 else
   setGpio(0, 0)
Activates a 3 stage sequential shift light. Also see the Sequential Shift Light project Given:
  • RPM input on timer input 0
setTickRate(15)
	r = getTimerRpm(0)
