RaceCapturePro Lua Scripting Examples
API Reference
setTickRate(30) function onTick() arm = getGpio(0) g = getAccel(1) if arm == 0 then stopLogging() end if arm == 1 and g < 0.1 then startLogging() end end
or
function onTick() if getAnalog(0) > 212 then setGpio(0, 1) else setGpio(0, 0) end
Given:
- RPM sensor on timer input 0
setTickRate(15) function onTick() r = getTimerRpm(0) if r > 5000 then setGpio(2,1) else setGpio(2,0) end if r > 6000 then setGpio(1,1) else setGpio(1,0) end if r > 7000 then setGpio(0,1) else setGpio(0,0) end end
Given:
function onTick() t = readAnalog(0) msg = {} msg[0] = t txCAN(1234, 0, msg) end
