MegaJolt Lite Jr.
Revision as of 18:45, 18 February 2007 by Brentp (talk | contribs)
The Megajolt Lite Jr. (MJLJ) is a fully configurable, stand-alone ignition controller designed to control a Ford EDIS 4, 6 or 8 crank-fired ignition module. It is an ideal ignition solution for carburated engines; it can also work in conjunction with compatible EFI systems. It is well supported with sophisticated yet easy to use Configuration Software.
Current Features
  • External Rev-Limit trigger output (The Ford EDIS module has no 'rev limit' signal, so an external circuit to disable the ignition coil is required)
  • Modern, easy to use, and customizable Windows-based configuration software
    • Load, configure and save Ignition Configuration
New with V2.7.x/V3.1.0 beta
  • TPS / Load axis calibration
  • Improved user outputs with hysteresis
Current Hardware
Version 3.x
MjljV3 MAP prebuilt.jpgMjlj v3 build step6 map.jpgMjlj v3 build step5 map.jpg
Older hardware revisions
Version 2.x
Mjlj v2 molex end.jpgMjlj v2 open case closeup2.jpgMjlj assembly complete.jpg
Ancient History
