RaceCapture App User's Guide
Revision as of 23:27, 3 January 2015 by Rdoherty (talk | contribs)
  • Linux: currently supported by running from source
  • OS X: port scheduled
  • Android: Beta available, contact us a [email protected] for access
  • iOS: port scheduled
Downloads
Discussion Forums
In the spirit of sharing and collaboration, please post all of your questions / testing results / feedback in the community forums.
RaceCapture V2 App/Firmware Discussion Forum
What's New
Check out some kickass new features:
Capable of running on Windows, OS X, Linux, iOS and Android, the new RaceCapture app will ultimately combine RaceAnalyzer and the current Mobile app into a unified configuration, dashboard and analysis solution.
The latest race track configurations can be automatically downloaded and synchronized from http://www.race-capture.com via the application. If your track is not in the list, email us at [email protected] and we will work to get it added.
Multi-Sector Timing
  • sectorTime - indicates the time of the last completed sector
  • sector - indicates the last completed sector
Separate Start/Finish Lines
Not yet implemented To enable auto-x/rally/hillclimb scenarios we've enabled the ability to define a separate start and finish line.
Predictive Lap Timing
Streamlined Sensor and Channel Configuration
Channel configuration has been simplified where possible with additional default settings that make sense. Automatic channel configuration wizards will help auto-calibrate things like throttle position, fuel level and and steering angle sensors.
CAN bus expansion
OBD2 support
Virtual Channels
  • Detecting gear based on RPM and speed ratios
  • Turbo intercooler efficiency by calculating the difference between inlet and outlet temperature probes
  • A calculated 'engine load' indicator by integrating RPM + Manifold Pressure Sensor value.
Lua Scripting CAN bus API
Channel Filtering
Analog, Timer and Accelerometer channels feature an adjustable dampening filter that allows you to smooth out sensor readings as needed. Examples of this use:
  • Filtering accelerometer readings for rough environments
  • Averaging fuel level readings to compensate for fuel tank slosh
Channel Customization
The concept of a channel has been formalized into a set of universal system level channels where min/max and unit labels can be customized. Additionally, user-defined channels can be defined for special purpose channels.
Improved Lua Scripting
  • Use the print() and println() to print out log messages which will show up in the scripting view. Great for debugging.
  • If a wayward script somehow crashes the firmware, the RCP watchdog will fire and start up RCP in safe mode, illuminating the red LED and bypassing script execution. Then, you'll have a chance to make fixes.
  • Functions have been streamlined and normalized for consistency. Additional Lua functions have been added to support virtual channels, OBDII and CAN bus messaging.
Improved log timing accuracy
Upcoming Features
Dashboard
  • Multi-gauge dashboard view
  • Lap Time view showing last, predicted, best time and delta from best
  • Raw channel monitoring view to show all known channels in a list
  • Lap Time + real-time accelerometer + gyro view
Analysis
  • Line charts showing channels over distance, with the ability to combine multiple channels into a single chart
  • GPS plots showing the line taken in reference to the center line of the track map
  • Sector times for each part of the track
  • Note, Due to the significant changes in the firmware, the RaceCapture .rcap configuration files are not compatible with the new configuration file format
Firmware
  • Windows: Check under Device Manager for a RaceCapture/Pro device under the Ports section.
  • Linux: When plugged in, a CDC-ACM device should show up. Check it by issuing the dmesg command; typically it will be /dev/ttyACM0
Application
Install the beta RaceCapture app after downloading the setup package from the downloads section.
Running
Editing Configuration
Auto track detection
  • Note: For the first time running you will need to download the latest set of race tracks by touching the cloud icon in the lower right corner of the app.
GPS Configuration
  • Note: Leave the Position, Speed, Distance, and Time of Day channels enabled for accurate analysis.
Analog Channels
  • Raw value
  • Simple linear scaling
  • Interpolated map
  • Note Channel #8 is fixed as a battery input channel and should not be changed.
Pulse/RPM Sensors
  • Channel Operation Mode: RPM, frequency, or pulse period
  • Clock divider: This specifies the operating range for measuring the pulse. This is typically left at 128.
  • Pulse Per Revolution / Teeth Per Wheel: This specifies the number of pulses representing a complete revolution of the wheel.
    • For RPM mode This value is typically set based on the number of cylinders and the number of coil packs used on the engine
Digital In/Out
  • Mode: Set the channel to input for reading digital on/off sensors, or output to use the channel in output mode to control a device.
Accelerometer/Gyro
  • Not yet implemented User interface for zeroing accelerometer/gyro channels.
Pulse/Analog Out
  • Output Mode Select either Frequency / Pulse Width Modulated (PWM) mode or analog output mode. Note, to enable analog mode you also need to flip the hardware dip switch on the RaceCapture/Pro main board.
  • Logging Mode Select either logging the frequency or the analog output voltage.
  • Startup Duty Cycle The default duty cycle when the system starts up.
  • Startup Period The default startup value for the pulse period. A larger number means individual pulses are spread further apart.
CAN Bus
OBD II
Telemetry
Scripting
Channels
